Rebuilt Transmission help
Old Aug 19, 2012 | 06:16 PM
br25's Avatar
br25
Default Rebuilt Transmission help
Hello all! I recently installed a rebuild 46re transmission in my 97 ram 1500 4x4. After installation i took it for a test drive only to find that my transmission sputters during acceleration. it almost feels like its shorting out or something. the rpms jump around like its slipping, but its brand new! im really confused. anyone out there had the same problems?
Old Aug 19, 2012 | 10:04 PM
gdstock's Avatar
gdstock
Check gluid level in Neutral. Make sure it is full.
Old Aug 19, 2012 | 10:26 PM
Jason_Dodge's Avatar
Jason_Dodge
Make sure engine is on and in neutral when filling. Then cycle through all gears. Did you flush the tranny lines?
Old Aug 19, 2012 | 10:32 PM
br25's Avatar
br25
Yep i flushed the lines and also checked the fluid in neutral. it is at the proper fill point
Old Aug 19, 2012 | 10:39 PM
QuadCabLuv's Avatar
QuadCabLuv
Check valve been deleted? It could be clogged and starving the tranny for fluid & pressure.
Old Aug 19, 2012 | 10:46 PM
br25's Avatar
br25
Yes i have deleted the check valve
Old Aug 19, 2012 | 11:24 PM
br25's Avatar
br25
what could cause a brand new transmission to to that? i mean its hard to completely describe what its doing with only words, but this is my 2nd transmission ive put through it and i dont even abuse my truck. i treat it well, and ive done transmission swaps before. I have double and triple checked my connections and lines and everything is in its proper place. quite frusterating...
Old Aug 19, 2012 | 11:30 PM
gdstock's Avatar
gdstock
What do you mean by "sputters?" Who rebuilt tranny? Did they install new solenoids and sensors inside the tranny? There are a couple places where you have to measure for shims in when rebuilding. If shims are reused, they may or may not work, depending on clearances. New frictins alter the space.
Old Aug 20, 2012 | 03:56 PM
br25's Avatar
br25
could it be the distributor or ignition coil?
Old Aug 20, 2012 | 04:05 PM
br25's Avatar
br25
or a crankshaft position sensor maybe?
