What the best heavy duty fan clutch to buy?
Got my '96 dodge vicious-v-10 that is creeping past 200 when I have the AC on in heavy traffic. I recon it's time for a new fan clutch. But I was hoping someone knew of a quality fan clutch that they purchased and are completely satisfied.
Anybody help?
Anybody help?
your problem might not be fan clutch. could be radiator or too much hot air from the AC condenser core on the front.
why do you think your fan is bad. with engine off, give it a spin by hand. turning with some resistance is good. free wheeling is bad
Although pricey, nothing I have seen or heard of beats a e-fan kit from TCP. Reduce engine load, reduce load on water pump thereby increasing pump life, and provides better cooling than mechanical fan. Looking at up front cost alone is only seeing part of the picture.
I am a believer.
I am a believer.
+1 make sure that's the problem. Try what dhvaughan said and also look to see if any fluid has leaked out of it. I've had good luck with fan clutches from NAPA on other vehicles. Haven't needed one for the Dodge yet.
Now, with everyone's help, I should have that AC condenser checked out. I just hate taking it in to these shops for that check-up; it will lead to a false diagnoses just for the sale. I wish I could check it myself.
Trending Topics
I've got a total of $150 in my electric rig.. I'd compare it to anything out there, and it is not even a fair comparison to any mechanical fan it is so much better..
I recently replaced one of the 16" fans.. the thing finally wore out after two years.. it didn't worry me because I was smart (smug, no?) enough to use a dual setup.. I looked at the wiring as the basis, and the fans themselves as expendable.. they were a whopping $16 apiece.. Pro-line, 2750cfm, 16".. I used the same fan to replace..
