plenum ordered!!
Old Aug 22, 2012 | 07:45 PM
crackajack92's Avatar
crackajack92
Default plenum ordered!!
ok with that being said, what else should i do thats cheap? i know i should do plugs wires etc.. but i dont have the money for that and the plenum lol. and how hard is this plenum going to be?
Old Aug 22, 2012 | 07:52 PM
QuadCabLuv's Avatar
QuadCabLuv
Do the timing chain. No ifs ands or buts. Just do it, whether you can afford it or not. Double roller please, bout $50.
Old Aug 22, 2012 | 08:00 PM
crackajack92
ok any tricks to that too?
Old Aug 22, 2012 | 08:16 PM
stewie01's Avatar
stewie01
No real tricks, need either a steering wheel puller or a 3 jaw puller to get the harmonic balancer off, depends on the year of your truck.
Water pumps are cheap, like $30, no time like the present to replace that....
Old Aug 22, 2012 | 08:32 PM
ReadRam's Avatar
ReadRam
Bypass hose and thermostat if it's old.
Old Aug 22, 2012 | 10:57 PM
crackajack92
the kit i just ordered has the bypass hose and thermostat from hughes. and i have a 96 2500 5.9l gasser
Old Aug 22, 2012 | 10:58 PM
crackajack92
also the water pump looke fairly new. no rust on the outside yet like a normal one would have after time..
Old Aug 22, 2012 | 11:21 PM
gdstock's Avatar
gdstock
Cheap? Really? If you would have researched here first, you would have saved enough on the plenum plate to pay for the double roller timing set!
Download the service manual in the FAQ/DIY section. It is cheap (free) and has all the "tricks" listed.
Old Aug 23, 2012 | 12:55 AM
crackajack92
i just thought it was one of those things where you "replace it if you can but if not it'll be ok"...
Old Aug 23, 2012 | 07:54 AM
woods4life's Avatar
woods4life
Should you replace the gears when you replace the timing chain or just the chain? How hard is it to get back in time?
