just another noob with a transfer case?
Old Sep 2, 2012 | 12:34 PM
Aubrey's Avatar
Aubrey
Disconnect your front driveshaft and put it in 4 and see if the yoke turns. If it does, the problem is not in the t-case.
Old Sep 2, 2012 | 02:07 PM
Wombat Ranger's Avatar
Wombat Ranger
Which yoke?
If the t-case yoke turns while in 4, there is a problem in it.
If the the truck is running, 4x4 is engaged, and the truck's stoppped, the front yoke shouldn't turn. If 4x4 is NOT engaged, it should. (Assuming the CAD is functioning correctly.)
Old Sep 2, 2012 | 09:25 PM
Hawkeyefan's Avatar
Hawkeyefan
well transfer case is back together and works good after I put it back together. I found out that who ever assembled it didn't do it right. The front axle is my problem now, ring and pinion are missing over half there teeth. So now it's time to rebuild that too.
Old Sep 2, 2012 | 09:30 PM
Hawkeyefan's Avatar
Hawkeyefan
Also to 4lo did still work,but 4h would just lock the front tires and wouldn't let them turn
Old Sep 2, 2012 | 09:42 PM
That's because the gears are trashed.
