plenum pan gasket
Old Aug 25, 2012 | 12:47 PM
pipeliner798's Avatar
pipeliner798
Default plenum pan gasket
what is the gasket that goes under the intake and plenum pan
Old Aug 25, 2012 | 01:12 PM
jasonw's Avatar
jasonw
Site Moderator
Fel-Pro Plenum Gasket, just the plenum gasket (also sometimes referred to as the "lower intake manifold gasket"), around $12 or less: MS95462
Fel-Pro Intake Manifold Gasket Set, upper gasket and lower gasket, around $25 or less: MS95392-1
Dorman Intake Manifold Gasket Set, upper gasket and lower gasket, around $50 or less: 615-310
Fel-Pro usually works great. I found these part numbers at O'Reilly Auto Parts, Advance Auto Parts, and Autozone. I double-checked at Rock Auto, they have the same parts for slightly cheaper (way cheaper for the Dorman set), but I didn't check shipping. If you search the forum, you can find a 5% discount code for Rock Auto that will help a little.
Make sure and replace the bolts that go through the plenum gasket, as they are widely referred to as the reason that caused the blown gaskets in the first place.
Old Aug 25, 2012 | 04:16 PM
It's Me Patt's Avatar
It's Me Patt
Rock Auto code (in your cart enter it where it asks "where did you hear about us" box)
107634687366547
Lots of info here: https://dodgeforum.com/forum/2nd-gen...um-thread.html
Old Aug 25, 2012 | 04:21 PM
It's Me Patt
Are you planning on replacing it?
