HELP!!! water in oil!
Old Aug 27, 2012 | 01:57 PM
Hilln's Avatar
Hilln
New Member
Angry HELP!!! water in oil!
HELP!!! Im new to this forum but ive got ALOT of useful info from here.... ok so i thought i blew a head gasket in my 98 ram with a 360 so i tore it down replaced the head gaskets all intake gaskets and installed everything back together to specified torgue... started the truck let it run for 20 mins and started smoking blue on decel... and water blowing out exhaust... so i took it all back apart..thought i had a cracked head bought a new head and replaced all gaskets again! started it today and its still getting water in the oil...and oil in the radiator...still smokes but i havnt seen any water come out exhaust... I do not know what else to do has good compression 140-150 on all cylinders... PLEASE HELP i really do not want to have to buy a new motor!!
Old Aug 27, 2012 | 02:11 PM
merc225hp's Avatar
merc225hp
It could take up to or more than three oil changes to get ride of say 80% of the water/anti freeze and multiple flushes of the cooling system to ride it of oil traces as well. Can you pressure test the cooling side of the system?
Old Aug 27, 2012 | 03:37 PM
Hilln's Avatar
Hilln
New Member
i let it sit and idle for about a hour and the smokeing almost stopped but it is still there on decel and no i do not have a pressure tester
Old Aug 27, 2012 | 09:27 PM
dhvaughan's Avatar
dhvaughan
beg, borrow, rent, or steal a cooling system pressure tester.
http://www.harborfreight.com/radiato...kit-65053.html
http://www.ebay.com/itm/MITYVAC-RADI...37e2d1&vxp=mtr
Old Aug 27, 2012 | 09:42 PM
gdstock's Avatar
gdstock
Originally Posted by dhvaughan
+1. That and a power bleeder are the next two items on my want list of tools. I also have one of these: Name:  combustiontester.jpg
This tells you if there are exhaust gasses in the coolant (turns yellow).
