Water pumps?
Old Aug 22, 2012 | 03:00 PM
woods4life's Avatar
woods4life
Default Water pumps?
Im looking at water pumps on rock auto and it says with or without a threaded heater port? Which should I get?
Old Aug 22, 2012 | 03:39 PM
Depends on what they mean by the heater port... if the are referring to the metal tube the heater hose goes to, that is not threaded. If they are referring to the bypass hose, that has a fitting that does indeed thread into it.
Old Aug 22, 2012 | 09:17 PM
dhvaughan's Avatar
dhvaughan
i think its referring to the heater hose pipe, which pushes in with an o-ring seal. i didn't know any of ours had a threaded heater hose pipe.
Old Aug 23, 2012 | 07:50 AM
woods4life's Avatar
woods4life
http://www.rockauto.com/catalog/raframecatalog.php
so which one should I go with?
Old Aug 23, 2012 | 07:51 AM
woods4life's Avatar
woods4life
I tried to do the link right to the water pump but it is only rock auto
Old Aug 23, 2012 | 09:47 AM
5533314 or 98170
Old Aug 27, 2012 | 08:49 PM
Chase Lejeune's Avatar
Chase Lejeune
I've never heard of a ram water pump with a threaded heater port. I would go with the unthreaded one. you can pull off your water pump before you order a new one and try to pull off the heater hose, it will be to the right of the bypass hose. make sure you bring your pliers, it can be a bitch sometimes.
Old Aug 27, 2012 | 09:38 PM
gdstock's Avatar
gdstock
Bypass tube goes in with O rings and is not threaded.
Old Aug 27, 2012 | 09:59 PM
Derick C.'s Avatar
Derick C.
My water pump is threaded for the bypass hose fitting. The driver side heater hose fitting is o-ringed.
Old Aug 27, 2012 | 10:18 PM
gdstock's Avatar
gdstock
Mine came with the 3/4" hose fitting in place. May vary by manufacturer.
I would call rockauto and ask them to be sure.
