Jumpy Speedometer P500
Old Aug 27, 2012 | 05:29 PM
Deluca119's Avatar
Deluca119
Default Jumpy Speedometer P500
Hey guys, so my speedometer is not working, I have the check engine light reading p500, No Vehicle Speed Sens Signal. Now, ive been doing some research and Im confused so i made a thread. I have a 97 Ram 1500, 5.9 auto tranny, i just got it. While traveling sometimes the speedometer will jump around, which leads me to believe the sensor is either faulty or not plugged in all the way or the wire is frayed. Rather than a bad ground in the circuit because then there would never be a reading. However, which sensor am I looking at the one on the differential or the one of the transmission. Thanks in advance!
Old Aug 27, 2012 | 05:30 PM
gdstock's Avatar
gdstock
Check both. And it could be a ground issue, although intermittant.
Old Aug 27, 2012 | 05:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'd start with the one on top of the rear diff housing.
Old Aug 27, 2012 | 05:41 PM
Deluca119's Avatar
Deluca119
Im going to check once the rain passes. I should also note that, I found in the engine bay a braided ground the frayed, I used alligator clips and hooked it to the battery ground but no difference. I recall from my old camaro that the braided ground controlled the gauges. What would you guys recommend to repair that? Just buying another braided ground right?
Old Aug 27, 2012 | 06:03 PM
gdstock's Avatar
gdstock
I would repair/replace any ground that is damaged. Check to make sure connection is clean and secure. I even added a couple extra ones to be safe.
Old Aug 28, 2012 | 09:27 AM
On the 97, the one in the trans drives the speedo. It's a gear driven signal generator.
Old Aug 28, 2012 | 02:43 PM
Deluca119's Avatar
Deluca119
Thats where I was confused. So, its the one behind the filler neck? Or its a mechanical speedo?
Old Aug 28, 2012 | 03:34 PM
Deluca119's Avatar
Deluca119
Just checked the voltages going to the sensor as per the haynes manual. Im reading 5.1, and 5.4, so theres powering reaching the sensor however, I should be reading 5 and 8. So it could be a bad ground causing less voltage.
Just took the sensor out cleaned both the sensor and pigtail terminals and going to see if theres any changes. It looks like on the sensor while the gear is intact one of the prongs is corroded and blue heres the pics
Old Aug 28, 2012 | 04:37 PM
Clean everything up good, and stick it back together, and see if it all works. That IS the correct sensor for the speedo.
Old Aug 29, 2012 | 04:39 PM
Deluca119's Avatar
Deluca119
No difference unfortunately. Looks like ill take plunge and replace it, less than 30$ not bad at all.
