Sunpro Super Tach II Wiring
Old Aug 29, 2012 | 12:12 AM
OliverWalley's Avatar
OliverWalley
Exactly. I should also add.....The tach needle does go to zero when the truck is running, the light works and dims when I dim the instrument panel lights.
Old Aug 29, 2012 | 12:20 AM
95RAM360's Avatar
95RAM360
I know this wont help now but im going to wire it to my truck tomorrow and see if it works...my truck does have factory tach though...dont know if that makes a difference....but i figure ill try it since i had it on my nissan and it worked and my nissan DID have a distributor...so i will let u know tomorrow on that...sorry i can be much more help than that right now
Old Aug 29, 2012 | 08:22 AM
Tach signal wire should go to the black wire with green trace from the coil connector. That's the wire the PCM uses to control the ground, which actually fires the coil.
Old Aug 29, 2012 | 02:20 PM
OliverWalley
Thumbs up Sunpro tach
Thank you 95RAM360 and HeyYou. Got it working. Just didn't have the splice to the black/green wire connected properly. Tach now works great.
Thanks
Old Aug 29, 2012 | 05:32 PM
95RAM360's Avatar
95RAM360
Hahaha...well looks like i can take mine off...i was comming to this thread to post mine works....but glad you got it
