A/c Pressure Readings
Old Aug 29, 2012 | 08:38 PM
DodgeRam10's Avatar
DodgeRam10
Default A/c Pressure Readings
Hey I just installed a ac line, evacuated the system to draw out moisture and tested to make sure it held a vacuum. Everything was fine. Started filling freon and on second can, before i realized it the low was at 50 psi and high was about 275. It is about 99* right now outside. According to this chart,the high is a little over. How do i release some or is this ok? Air inside seems cold..not sure.
https://dodgeforum.com/forum/1st-gen...solutions.html
Old Aug 29, 2012 | 11:11 PM
DodgeRam10's Avatar
DodgeRam10
anyone? I let some freon out and got the pressure to 41 and 245 and after a couple minutes it went to 45 and 250. Hoping that is good now but i was thing that maybe the readings were so high because of the heat from motor? If it was 100 outside and 110 in engine bay than the original readings woulda been correct right?
Old Aug 30, 2012 | 12:37 AM
SilverSS's Avatar
SilverSS
How big of a can are you using? I don't remember how many ounces our trucks take offhand but i think it's somewhere around 32 or 35 oz. The cans of r134a are usually 12 oz. Your pressures seem really high for just adding 1 can. What's the temp drops at the vents?
Old Aug 30, 2012 | 01:47 PM
DodgeRam10's Avatar
DodgeRam10
i used 12 0z cans, 1 full one and the second can has a little left but not much. Got a digital thermometer today to read the vents.
Old Aug 30, 2012 | 01:48 PM
DodgeRam10's Avatar
DodgeRam10
could there have been freon in the compressor still? My air compressor wasnt big enough to get a good vacuum for the vacuum pump but so it was at like 12-20 for an hour.
Old Aug 30, 2012 | 05:27 PM
DodgeRam10's Avatar
DodgeRam10
over a 15 min drive, the lowest it got was 63 and that was in park just idling, when driving it would stay between 67 and 72 and would fluctuate the whole time. the temp outside was between 98 and 110 today. Any ideas?
Old Aug 30, 2012 | 06:56 PM
DodgeRam10's Avatar
DodgeRam10
just checked the gauges again, started at 40 low side and 240 high side,after a couple min it went to 42 low side and 252 high side and inside air was 67* all at idle. Is this ok? seems like it should be getting colder to me and also seems like the air isnt coming out of the vents as hard as it used to but not sure on that,please any suggestions..
Old Aug 30, 2012 | 07:10 PM
gdstock's Avatar
gdstock
System takes about 32 oz for a full charge from empty. Temperature of cold air is dependent on outside air - it is the Delta T (difference) of ambient to refrigerated. Hotter outside, the less cool it will be inside.
Are the lines under the hood trying to freeze up?
Old Aug 30, 2012 | 07:30 PM
DodgeRam10's Avatar
DodgeRam10
suction line is cold,high side line is hot, i was just messing with it and realize now that when i rev it up, the low side drops and compressor kicks off than low side goes up and high side goes down. So why would the low side drop as i give it gas? Does that mean its low? I dont want to overcharge it because when its ideling its reading correct
Old Aug 30, 2012 | 11:16 PM
QuadCabLuv's Avatar
QuadCabLuv
Mine was doing the same and still is, i beleive its just still low on freon. Ive heard before thats its best to pull your pressure readings at 2k rpms.
