What's in my radiator????
Old Sep 14, 2012 | 07:20 PM
  #51
Flush the cooling system really well a couple times, and just drive it. See if the crap re-accumulates.
Old Sep 14, 2012 | 07:38 PM
  #52
adrenaline junky's Avatar
adrenaline junky
I could do that but it's the pinging that's really bothering me right now.
I was thinking.... If the intake manifold gasket had an issue could it be causing a lean condition on one of the cylinders? If I remember right, there are also cooland ports that hit the intake manifold...Could it be cucking coolant through the intake gasket? Say if maybe a bolt backed out of the manifold/head?
It's a guy thing.... I just want to turn the wrench and fix it. I just don't know what wrenches to start turning....
Old Sep 15, 2012 | 07:17 AM
  #53
have you fixed your plenum yet? If not, have you checked it?? How old are the plugs? Etc.
The two problems might be related...... but, I kinda doubt it..... I would go after the cooling problem first... and see if that didn't resolve the other issues.... plenum plate is famous for causing spark knock though.
Old Sep 15, 2012 | 08:20 AM
  #54
Ballfroguy's Avatar
Ballfroguy
Well if your pinging, maybe its fuel system related. Do simple stuff like new fuel filter, plugs (ngk v-power, its like I have a new truck), sea foam. If that dosent clear it up then check spark. Have you done a radiator system flush yet??
Old Sep 15, 2012 | 09:32 AM
  #55
Gary-L's Avatar
Gary-L
Veteran: Navy
How is changing the fuel filter going to repair the pinging issue? Especially considering the filter is part of the fuel pump assy.
Old Sep 15, 2012 | 03:02 PM
  #56
Ballfroguy's Avatar
Ballfroguy
Clean out old gas.
Old Sep 23, 2012 | 01:49 PM
  #57
adrenaline junky
SOLVED! Tore into the engine thinking that I was going to remove the heads and look what I found. The gasket was a mess. Both water and oil being sucked into the cylinders.
It was interesting that when I was removing the intake manifold it seemed like the bolts were a little loose. Even though I did the torque sequence when I installed them. This time I went through the torque sequence at least 5 times. Each time a couple of the bolts moves slightly. The last round none of them moved so I know this time that they are ALL torqued to spec now.
This thing runs like a new truck again. Smooth (for a dodge), no pinging, and it seems like a valve train rattle I had is now gone. Anyway I'm going to run a couple cycles of cooling system cleaner before I fill it up with coolant.
Just thought I would share the fix. Thanks for all the input. This forum is very helpful!
Old Sep 23, 2012 | 03:00 PM
  #58
Gary-L's Avatar
Gary-L
Veteran: Navy
Congrats. Now you owe the class a box of cookies!
Old Sep 23, 2012 | 05:17 PM
  #59
LegendKiller89's Avatar
LegendKiller89
Nice job man! Thanks for posting the answer to your problem.
Old Oct 3, 2012 | 11:41 PM
  #60
adrenaline junky
During this repair I noticed that there was oil in the plenum. I had already installed a hughs plate over a year ago and scratched my head a little as to why it had oil in it. ALL the ports were black with oil residue and the inside main body was coated with oil. I just figured it was pulled oil in through the intake gasket. I removed the plate, scrubbed the whole kegger and installed a new felpro gasket. I also replaced plug #5 since it looked like this again.
I have about 300 miles since the repair. It ran well for the first 100 then started pinging again. I pulled the plugs to do a compression test and #5 plug was already starting to look like the picture above. In addition the threads were covered in serious oil and there is an oil residue inside the plenum again. I did the compression test and all the numbers were in the 155 range except for cylinder 5. It was 170. I'm assuming from all the oil in there causing a great seal.
So I think what this is telling me is that somewhere in #5 cylinder there is something failed. Either a valve guide seal, rings, bad head gasket.... As I mentioned earlier in the post, new Odessa heads were installed about a year ago when one cracked. What would be the next thing to check? Any other suggestions?
Also I have drained the coolant twice and I'm running my 2nd prestone cleaner through it to clean up the cooling system mess.
Help me please. I love this truck, but I'm really getting to the end of my patience trying to fix it.
Thanks,
Mike
