Bad braking RAM 1500
Old Nov 13, 2015 | 07:59 PM
dbbd1's Avatar
dbbd1
Upgrade your front calipers to the LD 3/4 guys, and quality pads.
I assume that you mean "light duty" ram 3/4 ton units?
Which pads are you running?
Thanks
Old Nov 13, 2015 | 09:19 PM
Spillage's Avatar
Spillage
This is what I did...
https://dodgeforum.com/forum/2nd-gen...ml#post3266365
Old Nov 13, 2015 | 09:56 PM
dbbd1's Avatar
dbbd1
Thanks for that info. Will I need the ABS sensors too or was that just an upgrade you wanted to do at the same time?
Old Nov 14, 2015 | 08:08 PM
Spillage's Avatar
Spillage
I did them because I had ABS & brake lights 'on'... the rear was the issue, but at their age and miles, I was changing them all anyway.
You're just looking for a braking efficiency upgrade... If you don't have ABS issues, they don't have to be changed.
Old Nov 14, 2015 | 09:08 PM
dbbd1's Avatar
dbbd1
Thanks again, that's what I thought.
And, also thanks for the part numbers. I got parts ordered today and should be doing this soon (good thing I have a garage to do the work in).
