shifting problems
Old Sep 6, 2012 | 04:11 PM
rick king's Avatar
rick king
Default shifting problems
2001 ram 2 wheel drive auto trans 5.9 will not shift to second gear going up steep hill,I changed the shift solenoid,speed sensor,governor pressure sensor and governor pressure solenoid,new filter also,still have the same problem truck runs up to 3 thousand rpms or more an doesn't shift to a higher gear,please help Rick thanks
Old Sep 6, 2012 | 04:22 PM
Check the TV cable, and make sure it isn't sticking.
Old Sep 6, 2012 | 04:31 PM
gdstock's Avatar
gdstock
Does speedometer work?
+1 on checking TV cable.
How is the fluid level (and please tell us you used ATF+4 and checked it in neutral!)
Old Sep 6, 2012 | 04:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Might as well check it in case, but I don't think the TV cable as anything to do with 2nd to 3rd up shift. I'd say rebuild time.
21 - 494 AUTOMATIC TRANSMISSION - 46RE BR/BE
AUTOMATIC TRANSMISSION - 46RE (Continued)
CONDITION POSSIBLE CAUSES CORRECTION
HAS FIRST/REVERSE
ONLY (NO 1-2 OR 2-3
UPSHIFT)
1. Governor Circuit Electrical Fault. 1. Test using DRBT scan tool and repair as
required.
2. Valve Body Malfunction. 2. Repair stuck 1-2 shift valve or governor
plug.
3. Front Servo/Kickdown Band
Damaged/Burned.
3. Repair/replace.
