Anyone know what this is?
Old Sep 6, 2012 | 06:45 PM
dhvaughan's Avatar
dhvaughan
i'd pull the speed sensor out and look at it. it might have been replaced in the past, and broken off in the process. i stuck a picture above.
just a by the way. your 01 speedometer is determined by ring gear sensor, rear abs/speed sensor, pcm programming for "pinion factor", and tire size. gear ratio is not used in later years (98-01ish).
Old Sep 6, 2012 | 06:48 PM
ReadRam's Avatar
ReadRam
I concur, doesn't look like any of the clips or clutch remnants found in the bottom of my LSD diff couple months back.
Old Sep 6, 2012 | 06:55 PM
ramthis9501's Avatar
ramthis9501
The speed sensor is still there, but I'll look it over to make sure it looks fine. Just say the sensor is broken, can I take the one off the axle on my truck now and put on it?
The new axle is off of a 98
Old Sep 6, 2012 | 07:43 PM
dhvaughan's Avatar
dhvaughan
rockauto says the rear diff abs sensor for 98-05 are all the same.
Old Sep 6, 2012 | 07:48 PM
ramthis9501
Awesome thanks man
