Anyone know what this is?
Old Sep 6, 2012 | 04:19 PM
ramthis9501's Avatar
ramthis9501
Default Anyone know what this is?
Can someone tell me what this is? It was stuck to the magnet at the bottom of the differential. The gears still spin freely and look good... I just wanna make sure it's nothing major.
The gears seem to look good though, no missing teeth or anything.
Thoughts?
Old Sep 6, 2012 | 04:21 PM
Open diff? Or limited slip?
Old Sep 6, 2012 | 04:33 PM
kejobe's Avatar
kejobe
Looks open in the pic. Although Im not a specialist. Not sure what the piece is either.
Old Sep 6, 2012 | 04:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
That looks like the right size for speed sensor on top of the diff. A shim in the housing for it, or part of the sensor itself maybe ?
Old Sep 6, 2012 | 05:11 PM
ramthis9501
It is limited slip and the piece was inside the differential when I opened up the cover.
Old Sep 6, 2012 | 05:53 PM
stewie01's Avatar
stewie01
Does your limited slip still work?
Old Sep 6, 2012 | 06:08 PM
dlyter09's Avatar
dlyter09
Kinda looks like part of the pin that goes into the carrier.. WHO KNOWS!!
Old Sep 6, 2012 | 06:09 PM
ramthis9501
As far as I know... Both of the wheels turn when I spin the driveshaft.
Old Sep 6, 2012 | 06:21 PM
dhvaughan's Avatar
dhvaughan
the clutch retainer clips in the LSD like to break and fall into the diff, but that doesn't look like them at all. i don't recognize it as any component of the lsd.
i'm going with zman, might be a remnant piece of the ABS/speed sensor.
Its certainly not a piece of gear, ring, pinion, bearing, shaft, etc.
i'd just remove it and not worry about it.
edit. added this pic of the rear abs sensor in the top of the diff.
Old Sep 6, 2012 | 06:31 PM
ramthis9501
Awesome glad to hear some positive news... In that case, I think I'm gonna go ahead and seal it up later tonight with some rtv. Thanks for the help.
If it is a piece off the speed sensor, will my speedo be off then? I know it will be with the bigger gears, but I have a programmer to fix that.
