How hard to drop the fuel tank?
Old Sep 7, 2012 | 05:31 PM
sungod's Avatar
sungod
Default How hard to drop the fuel tank?
Have a leaking brake line and of course it happens to be behind the fuel tank. I could probably shade tree it and just run new line, but if it isn't too much hassle, I could drop the tank to get access inside the frame rail and do it right. How much hassle would be involved with moving it enough to get access to the brake line?
Old Sep 7, 2012 | 05:38 PM
stewie01's Avatar
stewie01
Easier to take off the bed if you have a guy or two around to help.
Old Sep 7, 2012 | 06:03 PM
sungod's Avatar
sungod
The problem is that even with the bed off, I still wouldn't have access because the line failed in the 'C' channel and the fuel tank is up against it.
Old Sep 7, 2012 | 06:05 PM
Just replace the entire line.... remove the old line that you can get to, leave the rest.
Old Sep 8, 2012 | 10:12 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You dont need to drop the tank completely. I removed the fill tube and straps, with the tank being held up with a jack and a 16" piece of 2x10. And just pushed the tank against the drive shaft. I had enough room to replace the line. Removing the bed will not help.
Old Sep 8, 2012 | 06:57 PM
plott hound's Avatar
plott hound
heyyou has the easiest solution.i just fished a new on through and left the old one there.
Old Sep 8, 2012 | 07:28 PM
Jigabop's Avatar
Jigabop
dropping the tank is bloody impossible!!!
I don't know why y'all are afraid of dropping your tanks...I've had my 35 gallon tank out of my diesel twice now..
first drain the tank
next roll your *** under there with a creeper and an impact gun, and a couple wrenches, unbolt the cross member under the tank, undo the clamps for the filler neck, and get a quick connect tool and get your head up between the bed and frame on drivers side and unhook the fuel lines and the sender plug from the canister.
once that's all unhooked, undo the two nuts holding the tank straps up (1 per strap) and drop the tank.
its 4 bolts, 2 nuts, 2 clamps, 2 fuel lines, and 1 plug. once all undone it drops right out.
I did the damn tank twice by myself! no help! and the first time it had diesel in it!!!use your leg while on a creeper when reinstalling it...leg holds tank up while you get straps hooked in their grooves and then push em up till you can get nut on the bolt.
its really not that hard, just make sure its empty first...
Old Sep 8, 2012 | 08:23 PM
95RAM360's Avatar
95RAM360
Dropping the tank is an easy process....
And to do the brake line you dont need to touch the tank...with mine i cut the line before the tank and fed a piece of brakeline between frame and tank until i could see it from the back end of tank then i just cut the line where its good and flare them up and put together....
So brake line you dont have to touch tank....if it was the fuel line then youd have to drop tank
Old Sep 9, 2012 | 11:41 AM
zman17's Avatar
zman17
It may be easier that way , but I personally would rather press the new line back into the plastic clips that hold it in place. So I know it's not rubbing on the frame or anything else for that matter.
Old Sep 9, 2012 | 12:41 PM
merc225hp's Avatar
merc225hp
+1, and most likely have a rattle that you can't find because the lines aren't clipped in.
