is it a miss?
What should I check next for a miss?My truck Still has a slight shudder around 45 mph...its so light its barley noticable,I'm starting to think maybe I'm just looking for it .Did a comp test&all was fine.New plugs New coil,cap rotor ,wires,wires routed per tsb .Had all suspension checked out like 5 times now.Trans place said the tranny&all is fine.
There's no other signs of any other problems...feels like maybe a small stumble@idle but if it is its so small to really notice.any ideas?p.s. did the plenum awhile back I also have a leaking hvac control assembly I'm gonna replace if I can ever find one.&Don't have cruise but I think that's Because of clock spring,When I bought the truck the airbag light was on cruise just went out recently can't find Any leaks in vacuum lines.gutted cat
