Stripped screw in headlight!
Old Sep 13, 2012 | 03:11 PM
Johnn123's Avatar
Johnn123
Default Stripped screw in headlight!
Hey all was putting my new xenon white bulbs in today, passenger went in fine, was able to reach in and twist it off, but i could reach in behind the battry to do the driver side. I decided to just undo the screws holding the headlight in and change em, figured it would be a 5 minute job. Well 20 mins later im snapping with a stripped screw on the bottom. Bought a bit and stripped screw extractor which did nothing. So now im left with one bulb still to be put in and and a stripped screw holding the headlight up pointing to the sky -.-
Whats the easiest way of getting it out? Im gonna need to get it out cause the lights pointed awful now. And yes i did search before posting but came up with nothing.
Old Sep 13, 2012 | 03:35 PM
Which screw did you strip? Mounting screw, or adjusting screw?
Old Sep 13, 2012 | 04:47 PM
Johnn123's Avatar
Johnn123
Adjuster, i ended uo taking a hacksaw and sawing a slot head in. By the way HY remember my name from the alliance?
Old Sep 13, 2012 | 11:16 PM
Johnn123's Avatar
Johnn123
Well i got them in, now my cab lights are gone... Where should i start with them?
Old Sep 14, 2012 | 09:28 AM
Check the wiring at the back of the headlight switch.
Do your other running lights work? Taillights, etc?
What was your name at TESA??
Old Sep 15, 2012 | 06:38 PM
Johnn123's Avatar
Johnn123
Every other light works fine. Wonder if its a bad ground ? And same name man haha
Old Sep 16, 2012 | 12:02 PM
Were the cab lights factory? Or installed later? I would go looking for where they get power....
I couldn't find you under that name?
Old Sep 17, 2012 | 08:28 AM
Johnn123's Avatar
Johnn123
Nope aftermarket, its a 1500. Not sure where the wiring is for em. Actually nvm my display name is just John there haha .
