Transmission's acting funny,
Old Sep 18, 2012 | 01:17 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by Doorknob77
And The Shudder isn't slight it's like im in 6th at 10 mph exactally! Should I get a new plenum plate also so the gasket wont go bad so soon? I saw a video in the plenum thread Is it a waste of money?
I'd say your cat is clogged.
Old Sep 18, 2012 | 06:18 PM
  #22
jondakotaguy's Avatar
jondakotaguy
1- Plenum- It's not a waste of money because the crappy dodge engineers that crappily <-- New word LOL... designed the engine decided to screw everyone that bought one.. it will in time at some point fail. The question is when..
But some of the people here with the problem already have gone through the ENTIRE process... Plenum; Cat; O2 sensor and beyond and still have the issues. Others (Me) My plenum is not blown yet.. <--- YET (key word) and have done all kinds of things under the sun.. Granted I only have the off idle shudder. (Still engine mounts to go.. Dooh!)
2- TCC- (Not TC) those are two different things. TC- Torque Converter (Thats the entire assembly) TCC- Torque Converter Clutch - which is what engages.
That's really easy.. does it go in at 45 MPH right on the dot.. push the OD button and turn it off.. does it kick down gear?
Put in 1st gear.. (for the low speed shudder) still there..
As far as the other.. I'm not expert but if there was a problem with the TCC it self I would imagine it would be kicking in and out.. like crazy.. and/or not engaging or doing it too soon.. same for the soloniod that controls it..
Granted we are talking about two different shudders here.
Old Sep 18, 2012 | 06:21 PM
  #23
jondakotaguy
I think we should consolidate all these threads into an all in one thread.. for these 2 issues.. Off Idle shudder and TCC Lockup Shudder.
Old Sep 19, 2012 | 08:30 AM
  #24
dodge fan 001's Avatar
dodge fan 001
well, seems to me like the tc is locking up way to early of idle shutter dunno could be many things. try driving with the tow button on that I believe will disengage the tc lock up. that can be 1 test for the tc problem if you have one. This is a picky problem Good luck....
Old Sep 19, 2012 | 09:50 AM
  #25
Doorknob77's Avatar
Doorknob77
Thanks, i Think im going to be driving with the overdrive off today, see how that works, I'll also be checking the plenum on friday after school. I'll let you guys know what's up with that. I'll also see if I can't check my catalytic today sometime. Any suggestions on a cat if It is clogged, I live in california, and can't seem to find a cat for my truck under 1,055 and I don;t think that's quite correct..
Old Sep 19, 2012 | 09:51 AM
  #26
jondakotaguy
he means turning OverDrive off to disengage the TCC..
But I think I would ask the question as far as the mid-speed shudder; when exactly does it do it?
When TCC is engaged (Over 45 with Overdrive engaged) at:
- constant speed
-When giving a little gas like going up a hill/incline kinda thing
-When letting off the gas a little from a constant speed
-Only when engages/disengages but once completed is smooth
If we can answer that maybe we can try and come closer to a more accurate idea of what to look for.
I'll be honest.. now and then while in OD i can feel a slight singular hiccup.. very very faint now and then.. but i would not call it a shudder. I can really only speak for the low end shudder off idle.
Old Sep 19, 2012 | 09:55 AM
  #27
jondakotaguy
Calli emissions is not going to let you run much other than stock. Catco is a really good brand.. very high quality.. it's not "High Flow" or anything (being those are really just the very bare min amounts of Ceramic they can get away with and call them high flow.. as thin of walls as possible" But the actual difference you will feel is hardly non.. I had both stock; Magnaflow and Catco.. they are all identical as far as performance goes. All are equally restrictive.
If you want something to last I'd say aftermarket I might go with Catco..
Mostly the cores (the actual bricks inside the cats) are all made by 4 companies and are all pretty much the same. At the end of the day your paying for a name..
What's important is like Catco Vs. Magnaflow.. Catco meets and exceeds the EPA regulation of the brick they use.. where as Magnaflow.. uses the least amount of material allowed which is a thinner walled brick.. and slightly smaller.. thus how they coin the term "High Flow" but it is much easier to blow one out under certain conditions.
Old Sep 19, 2012 | 12:44 PM
  #28
Doorknob77's Avatar
Doorknob77
The shudder starts at exactally 40 mph right when i hit fourth gear, and its like 10 in 6th if you know what I mean. I drove with the od off today hit 40 and no shudder, so tcc maybe? But the shudder gets worse the more gass I give it in 4th thats what made me think transmission. And I drive an overpass everyday three or four times a day never had any chugging, actually not even the shudder. there isn't any sound either, but the vibration is insane!
Old Sep 19, 2012 | 12:45 PM
  #29
Doorknob77's Avatar
Doorknob77
When I hit fourty that is----^
Old Sep 19, 2012 | 02:02 PM
  #30
It's Me Patt's Avatar
It's Me Patt
- constant speed
It happens as soon as I hit 40mph..The rpms will drop to 1100-1200 and shudder away..Now, I can do two things to prevent the shudder from happening..Continue through 40mph to 50mph at a higher rpm range say 1500-2200..Guess I'm motorin' through that bad zone..Or, if I keep the OD off (below 55mph) and it won't happen then either..As you know it also shudders off a roll (idle speed) always..Except, when I'm stopped but in gear and on a slight incline..we've all been there before..It's like when your at a light on a slight enough incline that you can take your foot off the break without rolling foward..it's like that and that's the only time it won't shudder at idle....sigh
