Need help ASAP!
Old Sep 19, 2012 | 07:20 PM
crackajack92's Avatar
crackajack92
also how do i get the other half of that hub assembly off??
zman17's Avatar
zman17
Retired Moderator - RIP
Yup, forget that shaft. As HeyYou stated about the wheel(s) passing you, also you could kill someone in the process.
Old Sep 19, 2012 | 07:35 PM
crackajack92
so what would you suggest buying another whole passanger side shaft or just buying u-joints and stub shaft?
Old Sep 19, 2012 | 07:36 PM
Check the junkyards, and see what you can come up with. If you can get the whole shaft from the yard, with a good joint in it, just swap out the whole thing. If not, just get the stub, and a joint, and call it a day.
Old Sep 19, 2012 | 08:33 PM
crackajack92
yessir i understand. have any clue how much that stuff might cost? on a tight budget i really didnt expect this to happen but i guess i should always expect the unexpected!
Old Sep 20, 2012 | 09:04 AM
I find axles for anywhere from 50 bucks for just a used outer (with tone ring for 4WAL....) to around 300 for the whole axle new...... Cheapest were on Ebay, some of the used stuff I found on car-part.com was just stupidly expensive..... (350 bucks for JUST the outer axle stub?? USED?????? Seriously?????)
Keep in mind, that at some point, dana decided that thumping the threads some where the nut would normally sit when properly torqued would help prevent it from backing out..... Strange, considering there is also a cotter key, which they STILL want you to use.....
Old Sep 20, 2012 | 12:22 PM
zman17's Avatar
zman17
Try these guys. They are great. http://www.mintonmotorsinc.com/index.html
Old Sep 20, 2012 | 12:46 PM
crackajack92
on my first picture theres that plate with 4 bolts that is part of the hub assembly.. how do i get that off besides 2 prybars and a deadblow hammer?
Old Sep 20, 2012 | 12:49 PM
Sooper's Avatar
Sooper
That stub axle is trashed. Do NOT re-use it. Good way to watch your front tire pass you....
Agreed. That's junk pile scrap.
Old Sep 20, 2012 | 01:30 PM
zman17's Avatar
zman17
Just remove the shaft, your replacing it all anyway.
