offrod package axle swap
Old Sep 19, 2012 | 06:57 PM
1998ram5.9's Avatar
1998ram5.9
Default offrod package axle swap
Ok i can get a set of axles out of a 2000 dodge ram 1500 offroad package for fairly cheap. i wanna put them in my truck since they have 4 10 gears and limited slip. My truck is a 2001 dodge ram 1500 4x4 and im pretty sure they should bolt in no problem? Does anyone know for sure? Because the only thing i can think could be different is that maybe the offroad package axles might be thicker or something.
Old Sep 19, 2012 | 06:59 PM
stewie01's Avatar
stewie01
What is the front axle geared to? Gotta match front and rear diffs.
Oops. For some reason I thought you were only getting the rear axle.. Doh!
Old Sep 19, 2012 | 07:06 PM
Should be a direct bolt in. no troubles at all. (aside from the usual rusted bolts, etc.)
Old Sep 19, 2012 | 07:11 PM
1998ram5.9's Avatar
1998ram5.9
whoops i meant swap in the title and i cant wait to get the 410 in now!
Old Sep 19, 2012 | 07:26 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
They ARE bolt ins. There might be 2 things to compensate for: ABS (RWAL or AWAL) and rear disk/drum.
Old Sep 19, 2012 | 07:54 PM
1998ram5.9's Avatar
1998ram5.9
My truck only has rwal, if the offroad package has 4 wheel abs, i just wont have anything to plug in so i guess that wouldent get an issue and both trucks have drums on the rear
Old Sep 19, 2012 | 09:42 PM
clipper77's Avatar
clipper77
Impressive amount of miles on your rig.
Old Sep 19, 2012 | 09:55 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Good!
So you're already done yeah?
I'm not aware of any OREs with AWAL, but mine is RWAL, and this is not to say there aren't any OREs with AWAL.
Hopefully the LSD is not shot.
Let us know how it goes.
Old Sep 19, 2012 | 10:34 PM
stewie01's Avatar
stewie01
WhiteNuckle brings up a great point on the LSD, might wanna pull the diff covers and check it out before you put in under your truck.
Old Sep 19, 2012 | 11:35 PM
JSTMoto's Avatar
JSTMoto
I agree. The factory LSD isn't exactly the most robust in design either. Might as well check it and repair it if necessary now so it won't cause down time later.
Best case scenario, you won't find any broken pieces and you'll simply be putting fresh gear lube in there which you should be doing for the swap anyway.
