94 ram 1500 brake issue/smoking
Old Sep 21, 2012 | 02:09 PM
94DDiesel's Avatar
94DDiesel
Ok, I have my buddy who is a mobile mechanic ASE certified etc, coming out to fix my truck tonight. Now the question is, he is having me buy the brake line from autozone, I am buying a couple 6ft long pieces and 1 30" piece to be safe. It is 3/16 brake line, he said he can put the bends in it etc. Now my question is what are the fitting sizes for the front and rear normally? Is it all 3/16?
Old Sep 21, 2012 | 03:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The line itself is 3/16ths, The nuts on each end need to be matched up.
Old Sep 21, 2012 | 03:54 PM
They are either standard, or metric..... but, the line will come with the correct size nuts on the end.
Old Sep 22, 2012 | 06:50 AM
94DDiesel's Avatar
94DDiesel
Ended up just replacing ALL of the brake lines while we were at it! problem is fixed now, and stopping is much better. Didn't realize just how bad all the lines were until we swapped them. Also I just got my build sheet through the local dodge dealer and they said my truck has a few recalls that were never adressed..... #1 being the ignition switch wire behind the steering column.... apparently they have a tendency to overheat and burn. specifically when you use your blower for heat or a/c. Well it just so happens the day this all happend and something plastic smelling burned, It was very cold and rainy so I was using defrost on high and shortly after this happend.
Now that I have checked, I realize my blower only works on 2 settings....OFF, and MAX. So I am thinking I found the BURNING plastic behind my steering column problem. Will keep this updated once I have the dealer do the recall work monday!
Old Sep 22, 2012 | 06:54 AM
94DDiesel's Avatar
94DDiesel
PS. Thank you for all your help HeyYou, Zman, and dodge dude! I appreciate it. Also were you by chance in the military HeyYou? I am just asking because of your name? I.e. A DS catches you doing something wrong normally you will hear HEY, YOU! Before they swoop down on you lol.
Old Sep 22, 2012 | 09:30 AM
I like to pretend I got my name from the Pink Floyd song.... but, in all reality, your supposition is closer to the mark..... Yes, I was in the military. USAF, Security Specialist. (cop......) I got to walk around with cool guns, and watch B-52's rust.
Old Sep 22, 2012 | 12:21 PM
zman17's Avatar
zman17
Replacing the blower motor resistor will most likely cure that problem.
http://shop.advanceautoparts.com/web...motor+resistor
Old Sep 22, 2012 | 04:51 PM
94DDiesel's Avatar
94DDiesel
I figured as much! I was an Army MP :P Before I went infantry that is. GARRISON military law enforcement blows lol!
Old Sep 22, 2012 | 04:52 PM
94DDiesel's Avatar
94DDiesel
Also thank you for the solution to my blower issue! Ordered the part today! We will hope I have time to fix tonight!
