'96 - Please help me diagnose rattling in the front.
Old Sep 21, 2012 | 11:29 AM
crslolbkr's Avatar
crslolbkr
Question '96 - Please help me diagnose rattling in the front.
My '96 Ram 1500 4x4 has had a bit of a rolling rattle in the front since I got it a few years ago. It was very faint then, like a ticking noise, but now it's alarming. It sounds like a part has come undone and is dragging underneath. It hasn't though. At it's worst (higher speeds - 40 mph), it kinda sounds like a roller coaster getting pulled up the first hill, except for not quite as precise and consistent. At very low speeds (5 mph) it sounds like someone kicking a ratchet down the street.
I replaced the wheel bearing/hub (pain in the neck) because the wheel was wobbling when lifted. That did not help at all. It needed done though, so no loss there. I don't want to just start replacing parts that aren't bad though.
Using my description, I wonder if anybody has experienced this same thing. Maybe someone has some good diagnosis techniques to help narrow it down.
Old Sep 21, 2012 | 11:48 AM
zman17's Avatar
zman17
Retired Moderator - RIP
One or both front axle ujoints are bad.
Old Sep 21, 2012 | 11:54 AM
crslolbkr's Avatar
crslolbkr
Thanks!
Old Sep 21, 2012 | 09:04 PM
dhvaughan's Avatar
dhvaughan
test axle u-joints with truck on the ground, sitting still. grab the front inner half of the axle where it goes into the axle tube and twist it forward and backward. there should be no movement, no play, no click or clack sound between the inner and outer half of the axle.
