I can't find a part on the ABS, please help.
Guys,
I have replaced most parts on this truck, some twice. So, I truly feel ashamed that I can not located the ABS Control Module. I know I need to jump pin 13 to ground to read the codes. But I can't find this thing.
I have read its below the cowling. Are we talking the cowling (windshield wiper plastic plate)? Thats what I call the cowling, but I don't see anything below it. Is it supposed to be on the firewall below the cowling, cause it aint there. Is it under the cowling as in do I have to remove the cowling?
Frustration, frustration, frustration.
Oh, by the way its a 96 Ram, 2 wheel drive w/ a 5-speed.
Thanks,
Jason
Thanks,
Jason
The data link connector is the OBD2 port under/at the bottom of the knee panel on the drivers side.
From the 96 fsm; To retrieve a DTC place the ignition key in the. RUN position. Then momentarily ground pin 13 of the Data Link Connector. When the ground is removed the ABS and Brake Warning Lamp will begin to flash. The initial flash will be a long flash followed by one or more short flashes. The long flash indicates the beginning of the DTC number. The short flashes are a continuation of the DTC number. You must count the long flash and short flashes for an accurate trouble code number.When the DTC has been retrieved compare it to the Diagnostic Trouble Code Chart (Fig. 9).
Merc,
You are the man. Why can't they just say that. I have spent hours trying to find the Data Link Connector. I thought it was something specifically just for connecting to the broke controller.
Ok. I connected the pins and it had the following blinks. I thought it could only do one trouble code at a time.
I get one long blink followed by one short blink.
Then after a pause, I get 4 short blinks. The four short blinks keep repeating until I disconnect the battery and clear the codes.
I did it again and got the exact same codes. So is it two codes, a 2 and a 4? All help appreciated.
I believe the 1 short then 4 short blinks is a code 14, which would be ECM program check failure.
This way of checking ABS system has not been available since 97, and now I see why..
Its pretty vague...
Maybe someone with more experiance with these DTCs will chime in.
Its pretty vague...Maybe someone with more experiance with these DTCs will chime in.
Trending Topics
DIAGNOSTIC TROUBLE CODE (DTC) DISPLAYED DIAGNOSTIC TEST
(38) WHEEL SPEED MISMATCH 11A
(41) RIGHT FRONT ISOLATION SOLENOID OPEN 12A
(42) RIGHT FRONT DUMP SOLENOID OPEN 13A
(43) RIGHT FRONT ISOLATION SOLENOID SHORTED 14A
(44) RIGHT FRONT DUMP SOLENOID SHORTED 15A
(45) LEFT FRONT ISOLATION SOLENOID OPEN 16A
(46) LEFT FRONT DUMP SOLENOID OPEN 17A
(47) LEFT FRONT ISOLATION SOLENOID SHORTED 18A
(48) LEFT FRONT DUMP SOLENOID SHORTED 19A
(51) REAR ISOLATION SOLENOID OPEN 20A
(52) REAR DUMP SOLENOID OPEN 21A
(53) REAR ISOLATION SOLENOID SHORTED 22A
(54) REAR DUMP SOLENOID SHORTED 23A
(61) RIGHT FRONT RESET SWITCH CLOSED 24A
(62) LEFT FRONT RESET SWITCH CLOSED 25A
(63) REAR RESET SWITCH CLOSED 26A
(65) MAIN RELAY OPEN 27A
(66) MAIN RELAY SHORTED 28ATEST 1B CHECKING THE SYSTEM FOR DIAGNOSTIC TROUBLE CODES (DTCs)
(68) PUMP MOTOR STALLED 30A
(70) CONTROLLER/VEHICLE MISMATCH 35A
(71) RAM READ/WRITE Replace CAB
(72) ROM CHECKSUM Replace CAB
(73) WATCHDOG Replace CAB
(78) FOUNDATION BRAKE 31A
(81) BRAKE SWITCH CIRCUIT 32A
(88) BRAKE WARNING LAMP (RED) CIRCUIT 33A
(89) ANTILOCK WARNING LAMP CIRCUIT 34A
DRB “NO RESPONSE” MESSAGE 36A
BLANK DRB DISPLAY 37A
(21) RIGHT FRONT SENSOR OPEN 38A
(22) NO SIGNAL FROM RIGHT FRONT SENSOR 38A
(23) INTERMITTENT SIGNAL FROM LEFT FRONT SENSOR 38A
(25) LEFT FRONT SENSOR OPEN 38A
(26) NO SIGNAL FROM LEFT FRONT SENSOR 38A
(27) INTERMITTENT SIGNAL FROM LEFT FRONT SENSOR 38A
(35) REAR SENSOR OPEN 38A
(36) NO SIGNAL FROM REAR SENSOR 38A
(37) INTERMITTENT SIGNAL FROM REAR SENSOR 38A
Master tech IIRC, I think those are 3rd gen codes.
The 2nd gens after 97 need a DRBII to read ABS.
Up to 97 Shorting pin 13 to ground would reveal a small collection of codes (about 15)
3rd gens can read ABS codes by key trick, and those numbers seem familiar.
on the first gen trucks they hid those things behind the glove box. i would guess the newer trucks would have a similar setup.
