Tips for power and gear ratio
Old Sep 25, 2012 | 01:05 PM
rthompson's Avatar
rthompson
In Arizona the only areas that require emissions is Phoenix and Tuscon. So outside of those citys there is not emission laws so cat converters mufflers and all that are not required. So a chip and headers are the best way to go for the next steps? I called a few places about my gears to a 4.10 and they are quoting $500+ for labor alone.
Old Sep 25, 2012 | 01:24 PM
merc225hp's Avatar
merc225hp
If there is one left Mopar performance pcm, P5249935 Engine Controller (1996 5.9L ATX Ram), or you can have B&G reflash your pcm or SCT your pick. Chips are junk waste of cash. That is about right for gear work labour expect to be around a G (per diff) when all is said and done, is your truck a 4wd or 2wd.
Please take the time to add more info about your truck in your sig, you will get much better help if we have all the info about what you have done to it.
Old Sep 25, 2012 | 02:09 PM
rthompson's Avatar
rthompson
Ya I have looked at chips off and on and thinking to replace the whole system if im gonna go that way. And thanks for the heads on the 4.10 price, wanna make sure that was right and not a rip off.
Old Sep 25, 2012 | 02:30 PM
merc225hp's Avatar
merc225hp
Talk to Hemi Fever about a SCT tuner lot's to people like them, much better than a chip. What do you mean replace the whole system? pcm?
Thanks for adding your info.
Old Sep 25, 2012 | 05:05 PM
Hahns5.2's Avatar
Hahns5.2
The feds disagree with you.
I don't care what you do, just don't spread misinformation.
Old Sep 26, 2012 | 10:57 AM
rthompson's Avatar
rthompson
I work State law Enforcement in Arizona, Federal law says there has to be some kind of emissions system in the state and Arizona only applys that in those two citys. And that is all there required to do.
Old Sep 26, 2012 | 11:06 AM
Adobedude's Avatar
Adobedude
Yep....It's a federal law, running without a cat anywhere could result in a huge *** fine.
Old Sep 26, 2012 | 01:06 PM
stewie01's Avatar
stewie01
Why is everyone so worried about the Feds? Is the EPA gonna come look under your skirt? I can see worrying about the cat in areas where emissions are thoroughly checked, but in some areas, no one cares, there are no emissions enforcement from the local authorities, no vehicle inspections for people to check for catalytic converters....
Some areas are much more strict on emissions then others, those are the places I'd worry about.
Old Sep 26, 2012 | 02:20 PM
redhemi06's Avatar
redhemi06
no cats all day long
Old Sep 26, 2012 | 06:58 PM
Wombat Ranger's Avatar
Wombat Ranger
Hahns is right, it just comes down to whether you wanna obey the stupid rules that no one enforces. Me personally? Screw the federal nanny laws. I have no cat and I don't plan to have one unless I move to an area that requires testing. But one could end up with a $10000 or more fine for it if someone decided to care.
