Tips for power and gear ratio
Old Sep 24, 2012 | 01:03 PM
rthompson's Avatar
rthompson
Default Tips for power and gear ratio
I have a 1994 dodge ram 5.9. Right now I am running Iridium plugs, 8.5mm wires, K and N CAI, 180 degree thermostat, with duel 3" straight pipe exhaust and no cat converter (legal in my state) and the plenum is replaced. What else can I do for power that does not include huge cash investments?
Also I see people talking about gear ratio, I have a stock transmission what is a good gear ratio and how do I change it? (I can do basic stuff but never learned this). Any help would be great.
Old Sep 24, 2012 | 01:19 PM
stewie01's Avatar
stewie01
Not a great deal you can do for power without spending $$$$. If you didn't replace the timing chain with the plenum that needs to be done, double roller's are cheap at rockauto.com
HarlandSharp 1.7rr are a good upgrade I think.
If you're running stock sized tires then a 3.92 gear ratio would help a bit, 4.10s or lower if you have large tires.
If you aren't familiar with changing gears and don't have anyone around that does know how, I would take it to a shop, too much can go wrong if it's not done 100% correct.
Old Sep 24, 2012 | 01:22 PM
rthompson's Avatar
rthompson
The tires on it are not a whole lot bigger then stock, the stock was 225-75-16 I have 265-75-16, a little bigger but not huge lift kit tires. So 4.10? would be good? And I planned on a stage 2 chip and headers. I guess RR are a good way to go.
Old Sep 24, 2012 | 01:25 PM
stewie01's Avatar
stewie01
I had a brain fart! I totally forgot about the SCT Tuner! Hemifever sells SCT Tuners which are a great help for these motors, around $265 for 3 canned tunes I think.
4.10s would probably be a good choice.
Headers would be a nice choice.
Old Sep 24, 2012 | 01:55 PM
rthompson's Avatar
rthompson
I called to get a few quotes for the ratio to go to 4.10, never thought it costs so much. All quoted $600 in labor alone.
Old Sep 24, 2012 | 02:06 PM
hemifever's Avatar
hemifever
SPONSOR
I can't do the '94 with SCT. Has to be '96 or newer unfortunately
Old Sep 24, 2012 | 02:18 PM
stewie01's Avatar
stewie01
Doh! Should have recognized it was OBDI, my bad..
Old Sep 24, 2012 | 05:04 PM
Hahns5.2's Avatar
Hahns5.2
It's not legal in any state.
Where do people get this notion?
Old Sep 24, 2012 | 06:05 PM
stewie01's Avatar
stewie01
Because honestly, who cares what the feds say has to be under your car/truck when the local authorities don't care nor enforce anything? Or if there's no emissions testing or vehicle inspections?
Old Sep 24, 2012 | 06:40 PM
jondakotaguy's Avatar
jondakotaguy
When I adjusted my TV Cable the truck has a little more pep accelerating.. Shift point's changed a little and better power when shifting to the next gear.
Thread in the DIY section.
