Big Truck Look For Cheap?
Once you get to 3" lift there are more parts needed, go look at some of the good 3" kit's and see what's included in that kit.
Lifting your truck can get expensive fast. If you do it on the cheap you risk breaking things that are going to be at steeper angles and under more stress. I understand that you have no intention of wheeling your truck, but you can do it right once, or cobble together a franken-lift that you build as you break parts and find limitations.
Being patient and saving for the 5" lift is probably the way to go, but it will probably be the hardest for you to do. Instant gratification is a cruel mistress. If you go with the body lift I would imagine you would need to either modify your fan shroud or lift your engine as well.
I would love to get a 5 inch lift but that's too expensive plus ill have to pay someone a lot of money to put it on. Plus my small tires wouldn't look right on the truck with a big lift.
Could I just get one of those +3 in the front and +2 leveling kits off eBay?
I'll be ordering them +2 spacers tomorrow so when I get them on I'll tell you all what I think of them.
No... Anything over 3 inches requires more parts. Either do it right or dont do it at all.. If you want a leveling kit you are limited to 2 or 2.5 inches... 2 inch wheel spacers are going to eat your front end up like thats its job.... I had 1.5 inch spacers on my truck for only 2 weeks.. My brand new wheel bearings were complete junk after those 2 weeks....
What about any of these? And has anyone else had problems with wheel spacers? I wanna know of the problems before I order them tomorrow.
Spacers I was planning on getting:
Wait and see what others have to say. If you really want a leveling kit I have 2 that you can choose from. Front springs and shocks.. They wont require any additional steering component parts..
I have one of those "frankin-lift" set ups, 3500 diesel coils-$40 from junk yard, add a leafs $40 ebay, and blocks out of a 72 power wagon which were 1.5" higher than the stock ones. The add a leafs i got were like the ones the op posted, they only did like an inch and a half, if that. Overall i got 2.5-3" of total lift. I have to agree with the general consensus that the wheel spacer are bad, havent heard any good things about em
