Engine stalls when clutch is engaged?
Old Sep 29, 2012 | 04:15 AM
dont dodge it ram it's Avatar
Default Engine stalls when clutch is engaged?
Hi everybody I could really use some help with my problem. I have a 2000 Ram 1500 with the 5.2L 318. I just did a transmission swap and put in a NV3500 5 speed tranny. The truck runs great and shifts awesome. I had no problems the first time I took it for a drive. But now I'll be coming to a stop, push in the clutch, and the engine stalls! It doesn't do it if I give it a little bit of gas after I push the clutch in, or if I give it gas right before I push the clutch. But if I'm drifting to a stop in gear then push the clutch in, it will stall.
I'm not sure where the problem could lie, but my one thought is the computer. I didn't use the computer out of the 5 speed truck. I'm wondering if the 5 speed computer raises the idle because the transmission isnt dragging the engine along when coasting to a stop? My other thought is to replace the plugs and wires. I will probably do that soon if I cant figure out the problem, but I would like to drive it now. I dont really want to drive it until I figure out the problem though because its a pain in the a** to turn without power steering.
Any suggestions? Please help!
Old Sep 29, 2012 | 01:25 PM
gdstock's Avatar
gdstock
I assume it had auto trans? IAC setting may be different for auto vs std....don;t know for sure. May check IAC. Also, PCM may be looking for trans data and not seeing it so it is confused. Getting any codes?
Old Sep 29, 2012 | 02:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
IAC may simply be bad. Try cleaning it. And remove negative battery cable before doing so. https://dodgeforum.com/forum/dodge-r...n-the-iac.html
And like GD said, the PCM is different for an auto trans.
Old Sep 29, 2012 | 03:13 PM
yes it did have an automatic tranny. i probably should have mentioned that. but yeah i considered that it could be a bad IAC but it ran fine with the auto tranny. i did get the codes checked and the normal ones appeared like trans temp, shift solenoid... ect. but the one that got me thinking was a transmission code: "park/neutral switch stuck in park". im wondering if the idle is low because it thinks that its in park. any idea how to change idle or fool it into thinkin that its in gear so the idle goes to normal for driving?
Old Sep 29, 2012 | 04:53 PM
Matt Nickerson's Avatar
Matt Nickerson
Having the correct pcm and harness would get rid of those codes, and may fix your idle issue.
But first, start with cleaning the iac (and maybe replacing it) its free and eliminates it as a possible cause.
Old Sep 29, 2012 | 06:51 PM
zman17's Avatar
zman17
The PCM needs to be flashed by the dealer or whom ever if you went from an auto to a manual.
Old Sep 30, 2012 | 04:23 PM
thanks for the advice. yeah i guess ill have to get it flashed i just dont know how much thats ganna cost me i didnt know if there was a cheaper way
Old Sep 30, 2012 | 04:27 PM
zman17's Avatar
zman17
Dealer only as far as I know.
