Oil Pressure changes
Old Oct 5, 2012 | 02:18 PM
  #21
wjxavier's Avatar
wjxavier
Originally Posted by Kurgen
Thanks wjxavier. It does help. Given the beautiful winters we have in Cleveland, along with the usually balmy accompanying temps, I think your advice on 5w-30 in the winter might be the ticket. Will give it a go. I will then switch it as you suggest in the spring for the 2-3 weeks of good weather we have.
Related, is there a better type oil for flat tappet lifter engines? I had heard Lucas makes an oil designated as a racing oil that is supposed to lubricate these older engines better. Do you know what the particular characteristic is that makes it better?
We (AMSOIL) makes a special blend called "Z-Rod". Its meant for engines in classic cars. Has a high zinc formula plus other ingredients and detergents beneficial to flat-tappet cam engines. Also is a good oil for storage as well
Old Oct 5, 2012 | 03:59 PM
  #22
Kurgen's Avatar
Kurgen
Thanks. I will look for it and give it a go. I have an older Vette that could use the help.
