starter fuses, and trans solenoids
Old Oct 3, 2012 | 03:42 AM
Reddnek's Avatar
Reddnek
Default starter fuses, and trans solenoids
ok couple of questions guys, first i tried to start my truck the other day and it blew the starter fuse twice finally got it to kick over and then it did it last night. any ideas? second i poped a p0753 code, something about 3-4 shift solenoid electrical, went to the parts store, and scanned/erased code came back on immediately, am i just looking at replacing that solenoid, and is that perhaps somehow electricallt tied to the starter blowing fuses and ideas?
Old Oct 3, 2012 | 03:29 PM
It's Me Patt's Avatar
It's Me Patt
need to check your wires, ignition, park/neutral position switch, starter relay and starter wires themselves..when you say fuse are you refering to the relay that's in the PDS? Next would be to test the starters volts/amps..but there could be something going on with the wires into the PDC if you have multi relays going or just a coincidence..so I'd start with those wires at the PDC first..post results..
Old Oct 3, 2012 | 03:49 PM
Reddnek's Avatar
Reddnek
no its not a realy its actually a fuse 20 amp, keeps blowing i will check voltage drops tonight, as for the trans im your saying check voltages for that too?
Old Oct 3, 2012 | 04:19 PM
It's Me Patt
check the relays and wires for the PDS to start with...
