battery connected backwards
Old Oct 10, 2012 | 09:31 AM
black99laramie's Avatar
black99laramie
Default battery connected backwards
some one connected my battery backwards, and now it starts right up as with no key in the ignition soon as I connect the battery the proper way.
Posted from Dodgeforum.com App for Android
Old Oct 10, 2012 | 10:44 AM
Sooper's Avatar
Sooper
Sounds like some of the harness melted together and is shorting the system. I'm kind of amazed the system still works and nothing blew.
The starter and IGN are getting 12V directly from the battery and while I am not sure where to start looking, I have a feeling this process might be a LOT easier if you source a used engine bay harness and just replace the whole thing.
Old Oct 10, 2012 | 01:12 PM
I'd find out who the h#ll connected my battery backwards....
Old Oct 10, 2012 | 01:17 PM
gdstock's Avatar
gdstock
.........and beat them with a stick...
Old Oct 10, 2012 | 01:20 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
True story: I once put instant coffee in the microwave and traveled backward in time.
Old Oct 10, 2012 | 05:03 PM
zman17's Avatar
zman17
Retired Moderator - RIP
LMAO..
Anyway, you could have hosed the PCM too. But Id try a new starter relay first.
Old Oct 10, 2012 | 05:16 PM
Sooper's Avatar
Sooper
Originally Posted by zman17
LMAO..
I almost though that too...but the engine runs. We all know how sensitive the PCM is to things and how one little issue will keep these engines from running. I think if the computer were hosed there is no way it was be able to maintain mixture and timing.
Old Oct 10, 2012 | 05:36 PM
zman17's Avatar
zman17
I should have worded that different as usual. But thats why I suggested starter relay. The hosed part of the pcm might be the voltage regulator or who really knows what else in the pcm. Anyway, I still would start with the relay, then move on to the wire harness in the column and onto the ignition switch itself. Just trying to not overload the OP you know?
Old Oct 10, 2012 | 06:18 PM
peshewa's Avatar
peshewa
I heard putting the battery in the engergizer bunny backwards means he just keeps coming & coming & coming....... I hope that joke didn't cause **** leakage for you guys!
Old Oct 10, 2012 | 06:48 PM
zman17's Avatar
zman17
No, that would be Ron Jeremy. LOL
