Calling all brake line/hose knowledge
Old Oct 11, 2012 | 02:00 AM
DamnDodgeRam's Avatar
DamnDodgeRam
Default Calling all brake line/hose knowledge
So I have about 6" of lift in the front of my 2wd ram. I can not find extended brake lines for the front. So, I'm stuck with 2 options.
1: Found some rear extended brake hoses, just my question is if the connections are the same as the front?
2: Relocating the mounting bracket at the top brake hose connector (if possible).
Which is the best option? please and thanks
Old Oct 11, 2012 | 04:51 AM
93grandzj's Avatar
93grandzj
you can get a custom made hoses to lengthen to desired need. My local orielly i frequent a lot for all my needs other then dealer only. he has a guy they can get hoses made up I want stainless steel lines for the front. don't think searching around you should be able to find some one able to make you new lines.
Old Oct 11, 2012 | 06:39 AM
Lone136's Avatar
Lone136
I got mine from RUSSELL PERFORMANCE, but I do have a 4 wheel drive. They should have them for your truck as well.
Old Oct 11, 2012 | 07:56 AM
HeikIlm's Avatar
HeikIlm
How about 4wd front hose? Remove the bracket from the middle and you get hose that's about 3 feet long.
