No noise from the fuel pump...
help us help you
all symptoms please. also explain what you mean by o2s have been cut off? are the o2s still screwed in and wires just cut..well I won't go into it without knowing first so, your turn..
The o2's aren't there. Just the wires. The previous owner took out the cat and half the exhaust. It turns over fine. We shot some starter fluid and it runs for half a second. There is no gas(sometimes a dribble) at the schrader valve.
And there is no helping me. HA!
When you turn the key to on, do the gauges come to life or just sit there? Also, check for voltage coming IN to the ASD relay from PCM with the key on. If you leave the key on and gauges do NOT work, do you get a "no bus" signal in the odometer?
It's the pump. We went back over everything and we found power was getting to the pump. Oh well. Would have been nice if it was just a wire! So I get to swap out the pump. Fun, fun.
Thanks everybody!!!!!!!!!!!!!!!!!!!!!!
