No noise from the fuel pump...
Old Oct 19, 2012 | 09:37 PM
Randy Curran's Avatar
Randy Curran
Default No noise from the fuel pump...
Truck won't start. No power getting to the fuel pump. Checked relays/fuses and everything else.
Help!
Old Oct 19, 2012 | 10:07 PM
It's Me Patt's Avatar
It's Me Patt
If the pump isn't priming and the relay is good then probably a bad pump..
Old Oct 20, 2012 | 10:08 AM
Randy Curran
But the pump can't work unless power is getting back there correct?
Old Oct 20, 2012 | 11:03 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you check to make sure NO power is getting to the pump? Or are you just assuming because you cant hear it?
Old Oct 20, 2012 | 11:14 AM
Randy Curran
We've checked all the wires going to it and no voltage.
Old Oct 20, 2012 | 12:35 PM
zman17's Avatar
zman17
Did you replace/swap the relay with another one? ASD and fuel system relays right? And do you have the service manual from the FAQ/DIY section so you can trace wires all the to the PCM ?
Old Oct 20, 2012 | 01:57 PM
aofarrell2's Avatar
aofarrell2
Check the relays, and check to make sure the Relay is getting voltage! If not it could be a bad supply wire, or else a bad PCM..
Old Oct 20, 2012 | 01:59 PM
aofarrell2's Avatar
aofarrell2
BTW Randy_Curran I noticed we joined DF within 3 days of each other!
Old Oct 20, 2012 | 04:43 PM
zman17's Avatar
zman17
He says he checked the relay(s) I'm wondering how they were checked.
Old Oct 20, 2012 | 05:27 PM
aofarrell2's Avatar
aofarrell2
Best way to check is honk the horn and if that works take out the horn relay and put it in place of the suspicious relay. Have a friend come over, check the relays, and check the fuses JUST TO BE SURE... I find a extra pair of eyes really helps...
