gearing questions and diff carraige
Old Oct 27, 2012 | 08:04 PM
newman1367's Avatar
newman1367
http://www.differentials.com/technic...carrier-breaks
Old Oct 27, 2012 | 08:40 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Newman's link confirms the carrier breaks. For D60/D70 4.56 and up is a break.
Yes the dodge D70 is 32 spline.
So....you want 4.10 or 4.56? I'm unsure from what you've posted as to your want.
For the front, I have a line on a ARB for a D60. It's in a front Dodge axle currently. I'd have to recheck the spline count. It was installed with 5.13 r&p. Priced at $750 It is 30 spline, but his outers are 35 spline Cromo. Passenger side CAD delete -- single shaft too.
For the rear, and not knowing what you're doing with the rig (i.e., types of terrain) I'll say a Detroit is plenty good. They are streetable and will chirp a bit if your turning a good pace. You can keep it down taking your time. Detroit will be more forgiving in this regard than the trutrac. Truthfully, I'd really recommend you get a factory LSD for the rear from your brief description. Check out the Cummins forums. Use "searchtempest.com" to search Craig's List.
Originally Posted by NCC74656
i think its the HD version of the D70. the front is a D60, i think the rear is a 32 spline if im not mistaken. im just getting frustrated at trying to find parts. it almost makes me want to keep the 3.55's. the sticker says its got a GVRW of 8800Lbs. the information i find online however states the D70 is 32 spline BUT is a 7500Lbs rating so idk if there is a difference.
i am trying to figure out what to do here and im at my witts end. i cant seem to find a good fit.
i currently run 36" toyo tires on a 99 long bed quad cab. its got 3.55 ratio with a factory limited slip rear. i am thinking i want to go up to 4.56 to bring things back to a stock feel. in the front i KNOW i want a selectable, either OX or ARB but the rear is whats screwing me over...
i cant find a LSD outside of a trac-lok or a detroit for my dana 70. i fear the detroit would be to extreme for a street truck that will only get some off road and also may end up towing. i can find some eatons for 4.10 and down but none for 4.10 and up, so im thinking... maybe i can take my factory LSD and use some kind of spacer or thick gears to add 4.56 in the rear. maybe i can buy a new carraige and install a lock rite, or i can spend a load more cash and buy an ARB for the rear. i just dont think i need a selectable in the rear...
what do you guys think? is a detroit to much? is a lock rite strong? should i go selectable? cost is a major issue here... if i can spend 600.00 on the rear diff instead of 1200.00 that would be huge. i CAN drop the money for a ARB front and rear but i have more to repair on this truck than just gearing.
thanks
Old Oct 27, 2012 | 08:43 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Don't forget to price in Master Install kits of both axles.
Old Oct 28, 2012 | 02:45 AM
Wombat Ranger's Avatar
Wombat Ranger
I vote detroit rear, and open front, unless you plan to really wheel that thing.
Old Oct 28, 2012 | 09:01 PM
NCC74656's Avatar
NCC74656
I have been stuck in stupid **** to many times to keep an open front. i was looking at an OX locker as its cheaper than an arb.
id be going with 4.56 gearing i believe due to my 35" tires, i think 4.88 is to high and 4.10 to low.
i will be hauling, street running, towing (5th wheel), and a few other uses. I see on the diff site that if i go 4.56 i will need a new carriage. i was thinking on rebuilding my factory LSD in the rear as it seems to be doing well and i worry that a Detroit may be to aggressive for towing. if i did rebuild the factory then i would need to use thick gears to utilize the factory carriage assembly on 4.56 gearing.
the only other thing im thinking of is perhaps changing spline count but i think i have the medium to heavy grade spines as is. if i remember correctly my rear was a 35 and front was a 32 (off the top of my head i may be wrong about that).
i was planing to buy all the bearings and shims for the rebuild but had not looked at a kit.
Old Oct 29, 2012 | 09:53 PM
Aubrey's Avatar
Aubrey
You should go locker up front and LSD in the rear since you want/need an all around kind of rig. With street and towing the LSD will be better and less expense in my opinion. I have an OX in the front and Auburn LSD in the rear.
Old Oct 30, 2012 | 12:05 AM
Wombat Ranger
The heavier the load, the less aggressive a detroit would feel. I understand where you are coming from though. Fyi your dana 80 rear = 35 spline, dana 60 front = 30 spline. I wouldn't worry about upgrading.
