Really frustrated, need front axle help
Old Oct 25, 2012 | 05:36 PM
silverlakexj's Avatar
silverlakexj
okay. At full left turn in 4wd, something is binding up. It doesn't at full lock in 2wd, but for sure in 4wd and I don't know where to go from here.
Old Oct 25, 2012 | 06:39 PM
silverlakexj
I talked to my dad who is a dodge guy. He says his 95 does click at full lock in 4wd too. And he told me not to worry if it doesn't do it in 2wd. I'm going to test it some more tonight after I put everyone to bed, but does this sound like it makes sense to anyone else?
Old Oct 25, 2012 | 07:40 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
You didn't say and people have done this by mistake, but don't be on pavement when in 4wd. If you were on pavement and in 4wd, then that would explain "binding" experience assuming everything was installed correctly.
Also, are you talking about 4hi or 4lo? Have any issue shifting the transfer case?
Old Oct 25, 2012 | 08:01 PM
silverlakexj
your right, I should have said I was on my dirt driveway. no problems shifting into 4hi. and I"m only trying 4hi right now, but will try low later tonight. I only messed with the front drivers side axle.
