big surprise....trannny problems
Old Dec 4, 2012 | 01:08 PM
  #31
aofarrell2's Avatar
aofarrell2
Originally Posted by northamerican
no water in fluid and ya i just checked level, shouldnt take like 30 - 45 seconds to engage tho right?
No it shouldn't. Is your shift lever adjusted right?
Old Dec 4, 2012 | 02:20 PM
  #32
northamerican's Avatar
northamerican
i dont know, is there a spec on it
Old Dec 4, 2012 | 02:21 PM
  #33
aofarrell2's Avatar
aofarrell2
Grab the FSM from the DIY section, it tells all in there.
Old Dec 4, 2012 | 02:47 PM
  #34
Nsmitty21's Avatar
Nsmitty21
I just wanted to double check that you are checking your fluid to while in neutral and not park. I know a few people that have thought their tranny was full and where wrong because they had the truck in park and not neutral.
Old Dec 4, 2012 | 04:49 PM
  #35
aofarrell2's Avatar
aofarrell2
Yeah good point.. ALWAYS check in Neutral on these Dodge trucks...
Old Dec 4, 2012 | 04:51 PM
  #36
dlyter09's Avatar
dlyter09
And at operating temperature with truck running
Old Dec 4, 2012 | 04:57 PM
  #37
aofarrell2's Avatar
aofarrell2
Running at curb idle speed for no less than 60 seconds.
Old Dec 4, 2012 | 05:44 PM
  #38
PendletonCowboy's Avatar
PendletonCowboy
I must have got lucky, my '98 had 148k and no trans issues when i sold it. My current '00 Ram has 100k (almost) and has had no trans issues.
However i did replace the water pump and steering box on BOTH!
Old Dec 4, 2012 | 06:50 PM
  #39
UnregisteredUser's Avatar
UnregisteredUser
ok, i dont want any "I told ya so's".
Tough. Told ya so!
my new used tranny is super slo to engage into drive or reverse when the weather is cold, but if i park in my heated shop its fine. What could that be.
Did you delete the anti-drainback check valve? And do you detect a bit of a whirring sound while it's sitting there thinking about maybe going into gear today?
If so, the workaround is to start the thing in Neutral and let it run for 30-45 seconds to fill the torque converter before shifting to a drive gear, and the fix is to install a remote ATF filter to get that anti-drainback functionality back. Oh, and when I say to start it in Neutral, I don't mean start in Park then shift to Neutral. Shift into Neutral before turning the key.
Try that starting in Neutral and waiting thing. If it does the trick, install the remote filter. If it doesn't... told ya so!
Both told ya so's are meant in good fun.
Old Dec 4, 2012 | 07:12 PM
  #40
northamerican
holy ****, starting it in neutral completely worked, WOW, what a relief, ok so now whos got5 a link to a remote system i need, or do i really need one, or can i just always start it in neutral
