Fuel in oil?
Old Oct 25, 2012 | 06:53 PM
lawliet's Avatar
lawliet
Default Fuel in oil?
I just bought my 1999 dodge 2500 V10 and everything looks and runs good but i just pulled the dipstick and it smells like fuel. I herd it could be piston rings. how expensive will it get worst case scenario? or could it be a simple issue.
Old Oct 25, 2012 | 07:00 PM
aofarrell2's Avatar
aofarrell2
Could be simple... Start with simple things. Check your PCV valve, check the crankcase air filter (also known as breather, not all have it), and most importantly do a compression check. The compression check will tell you a lot about the condition of the engine. Post the readings from the cylinders here.
Old Oct 25, 2012 | 07:02 PM
lawliet's Avatar
lawliet
ill take it to the mechanic tomorrow and get the readings from him
Old Oct 25, 2012 | 07:06 PM
aofarrell2's Avatar
aofarrell2
Ok. Make sure to write down the PSI and the cylinder number that reading came from.
Old Oct 25, 2012 | 07:07 PM
UnregisteredUser's Avatar
UnregisteredUser
It's somewhat normal for that to happen. When the key is switched off the ignition is killed immediately, so any cylinder that was in either the intake or compression strokes has got fuel in it. That fuel runs past the rings into the crankcase while the engine sits.
Run the thing up to normal operating temperature and at least ten minutes more, then check it. If it doesn't smell like fuel any more, you're probably good to go.
Old Oct 25, 2012 | 07:09 PM
aofarrell2's Avatar
aofarrell2
Very true. Check that out first, albeit I have never had gas smell in the oil unless one of the Crankcase ventilation systems was malfuctioning.
Old Oct 25, 2012 | 07:47 PM
lawliet's Avatar
lawliet
it just ran when i smelt it for about 15 minutes around town atleast. thats when i smelt it after i got home.
Old Oct 25, 2012 | 09:02 PM
aofarrell2's Avatar
aofarrell2
So are you smelling the exhaust or the engine oil?
Old Oct 25, 2012 | 10:06 PM
lawliet's Avatar
lawliet
i was smelling the dip stick when i pulled it out i just got done running it for another 20 minute drive. and still pulled it out the dipstick smells like gas on the end with oil so im just guessing its oil
on a side note its a very strong distinct smell
Old Oct 25, 2012 | 10:16 PM
crazzywolfie's Avatar
crazzywolfie
the oil in my 81 smells like gas when you let it idle too much and not reach operating temperature. i think you should keep driving it and when you get around to it do an oil and filter change. the gas should not hurt anything. if anything it should help clean up your engine. i have run my engine with about 5Litres of oil and enough gas that i could hear the crank splashing.
