Throttle Body Advice
Old Oct 28, 2012 | 02:54 PM
guzman's Avatar
guzman
Default Throttle Body Advice
I bought a 50mm "reworked" throttle body on ebay from amyk4422 in Decatur, Ga. but ended up getting ripped on it since I had not recieved it a month later...only BS from the seller but it sounds like PayPal is going to stand behind it this coming Tues. so I will be in the market for another one soon. I have a modded kegger in the garage but have been tempted to get a Hughes FI since I sold a rifle and have the cash now, anyway with the mods I have listed below maybe I should go for a 52 mm rather than the 50 mm when I buy another one. The truck is mainly used for pulling a 16 ft. horse trailer so I do like some power. I have 3.5 axle ratio and did install a Mopar performance computer right before I put in the H&S 1.7s last week. Another reason I wanted to go with the Hughes is to eliminate the blowout problem forever since my 60 yr. old back does not like to bend over in the engine bay too much anymore I have not checked any weld shops about welding a plate on the modded kegger yet either but that is maybe another option. Thanks for the help!!
Old Oct 28, 2012 | 03:03 PM
merc225hp's Avatar
merc225hp
In my op stay with the 50mm. The Mopar M1 is one other opt as a intake and will work well with your pcm and other mods. Time for 4.10 gears.
Old Oct 28, 2012 | 03:07 PM
UnregisteredUser's Avatar
UnregisteredUser
For towing duty, I'd stick with the kegger and a 50mm throttle body to keep the low end power. Just install an aftermarket aluminum belly pan on the kegger and call it good.
Old Oct 28, 2012 | 03:11 PM
gdstock's Avatar
gdstock
I did the kegger mod on mine as well as HS rockers. No problems with the kegger - and the 1/4" aluminum plate (not from Hughes - but from a member here that has an ebay site).
Welding plate on cast aluminum is not a good idea. (I used to work as an engineer for an aluminum foundry - that made intakes...).
Not quite 60, but my back is less than forgiving. I used 1/4" plywood across the front end and could lay across this to remove intake and other items. Don't forget to change to a double roller timing set while you are there. Also, trim the tab off tstat housing. With the tab, if you ever have to change tstat, it is more difficult to remove with using a stellar four letter word vocabulary.
An e-fan set up will help take a little more load off engine as well.
And just for the record....no pics - it didn't happen here!
Good luck, and welcome to DF!
Old Oct 28, 2012 | 07:15 PM
bwdakrt's Avatar
bwdakrt
x2. Good advise.
Old Oct 28, 2012 | 07:20 PM
guzman's Avatar
guzman
Default Kegger
Thanks for the replies and advice, I will just stick with the modded Kegger and a reworked 50mm TB. I do have a double roller chain, new oil pump, new distributor cap, rotor and cam sensor laying on the bench for when I get time to work on the truck again after I get the parts all gathered. I never thought about taking pics when I did the rockers :-( but I do have one of the kegger in progress and the mismatched spacers.
Old Oct 28, 2012 | 11:07 PM
jpsycoboy5's Avatar
jpsycoboy5
If you have the time an motivation it's pretty easy to just mod your throttle body I can post up the link I used later if yo want basically you just grind the horns down get a brake hone and do on top and bottom of the throttle plates and smooth the edges it's pretty easy if you have a drenel and you can save yourself a decent amount of cash to put towards other mods
Old Oct 29, 2012 | 04:20 PM
Ham Bone's Avatar
Ham Bone
Just mod your own throttle body. The top of butterfly valves are 47 and below 50. So just vote it out a little and cut all the air horns off. There's a couple DIYs on here about.
Takes maybe 1 hour including removal and reinstall
Old Oct 29, 2012 | 06:44 PM
guzman's Avatar
guzman
Default TB
I will check out the DIY on the Throttle Body. I usually have pretty good motivation but time is hard to find. Thanks.
