finally a cure for the annoying abs/brake lights!
Old Nov 1, 2012 | 06:14 PM
dodgetrucker75's Avatar
dodgetrucker75
Default finally a cure for the annoying abs/brake lights!
after a couple years of staring at thoes dang lights i finally sat down with the schmatics and went to studying...
as most of you probably know, the bulb for the abs can simply be removed, but the brake light is another story, i pulled the dash out and completly apart and found the curcit for the brake led, by breaking the small circut on the printed board in a very specific location, the brake light is now out and still works normally with park/emergency brake, however this is only for the 98-02, i could probably figure out the 94-97's if needed
i forgot to take pics but if anyone is interested in doing this, i have a spare dash at the shop and will try to get some up, unless someone has one handy they can post,
i did this because of the cummins swap, when i changed the pcm out, the lights were on ever since, my abs motor is also out, and because of a couple accidental drives with the e-brake set instead of spending the money trying to figure out all the programming gremlins, and other issues, this was my best option, usually you should fix your abs right but for some of us it is hopeless
Old Nov 1, 2012 | 09:17 PM
J415's Avatar
J415
So is this an actual fix for the ABS/brake light problem or is this just a "how to" for a band aid fix to turn off the lights ?
Old Nov 1, 2012 | 09:34 PM
aofarrell2's Avatar
aofarrell2
It's a band-aid fix...
Old Nov 2, 2012 | 12:46 AM
NCC74656's Avatar
NCC74656
i am digging into this with my mechanic on my 2500 ram. ive thrown 160 at it so far to replace the solenoids on the pump. i have not installed them yet but we believe this to be the issue. when i find out whats causing both lights to be on ill post it on here
Old Nov 2, 2012 | 08:01 AM
lone wolf #2's Avatar
lone wolf #2
I have a similar problem with my 98 sport, the lights would come on randomly but now are on steady and now the speedo does'nt work below 20mph. Does anyone know if these could be tied together, or am I dealing with two seperate issues?
Old Nov 2, 2012 | 11:02 AM
dodgetrucker75
no its not an actual fix, it just stops the abs system from turning on the light, as my system is beond repair
just pull the sensor located on the top of the rear axle housing and clean it, if that doesnt do it, replace the sensor and it should cure your problem
Old Oct 22, 2013 | 09:04 AM
lone wolf #2
Okay, I know this is an old thread but I still have a problem. I replaced the sensor in the rear end and checked the fuse but i am stil getting the abs/brake lights coming on on the dash randomly. Does anyone have any other advice?
Old Oct 22, 2013 | 09:34 AM
Matt Nickerson's Avatar
Matt Nickerson
If you have 4 wheel abs check your wheel bearings for looseness. Also take a look at your brake fluid level, if it's dropped any you probably have a leak in a line.
