water trouble
Old Nov 5, 2012 | 08:34 PM
jconlin's Avatar
jconlin
Default water trouble
so i was going down the road the other day and hit a puddle pretty hard because i didnt see it in time to slow down and about five seconds later truck sputtered out and died, i know something got wet but the cap is tucked way back behind the plenum and thats the only thing i cant think of that shouldnt get wet any insight? i would like to try to fix this so it does not happen again
Old Nov 5, 2012 | 08:52 PM
Ramzy's Avatar
Ramzy
Cap or the connectors on the PCM are the only thing I can think of due to past experience. I would dry out PCM connectors and use some dielectric grease. It happened to me.
Old Nov 6, 2012 | 09:29 AM
It's Me Patt's Avatar
It's Me Patt
Unless the cap was loose that shouldn't happen from a puddle unless it was like 10' deep. But likely wires. Like Ramzy said dielectric grease on whatever accepts it and stay out the puddles eh..It used to always happen to my old dodge work van even if it was like 6" deep. It would dry in several hours tho..
Old Nov 6, 2012 | 10:27 PM
jconlin's Avatar
jconlin
mine started and ran real rough after about 15 seconds of cranking exhaust sounded like a misfire, i plan on changing cap rotor wires and plugs soon so ill get some electric grease and dab up all the connections
Old Nov 7, 2012 | 12:27 AM
dhvaughan's Avatar
dhvaughan
if you don't find the problem, place an electric fan in/around/under the engine bay and blow air around to try and dry it out.
dielectric grease in each/every electrical connector will help.
