Transmission noise
Old Nov 9, 2012 | 03:00 PM
97ram318slt's Avatar
97ram318slt
Default Transmission noise
I was backing out of my parking space this morning, when i put the ram in reverse It made a noise as if the transmission was humming, also when accelerating i can hear a slight whine especially in lower gears.
is this normal noise? also the trans isnt slipping
Old Nov 9, 2012 | 06:43 PM
It's Me Patt's Avatar
It's Me Patt
check your fluid level with it warm, flat surface, and in neutral...w/e-brake on please If fluid ok post back..
Old Nov 13, 2012 | 02:28 PM
97ram318slt
well i checked fluid level in neutral after going to work and it was in the good range. yet after inspecting lines to the heat exchange in the radiator i found that the lower transmission hose is leaking a small amount. guess i get to remove the check valve now.
Old Nov 14, 2012 | 01:00 PM
It's Me Patt
pics of the parts I used when I removed mine is in 'my albums'..
Old Nov 14, 2012 | 01:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A little seepage at the connectors is pretty normal and wont cause the whining, which btw is pretty normal. You might try looking in the DIY section for "check valve removal" . Not saying that's it(the whining), but something that can't hurt to do.
Old Nov 14, 2012 | 03:20 PM
97ram318slt
zman i have been wanting for a reason to start to remove the check valve after reading the post in the diy section. i guess all the noise might just be normal since it is only when i first start up in the morning to leave.\
Thanks patt i will have a look.
Old Nov 14, 2012 | 04:24 PM
zman17's Avatar
zman17
Drive it until that 46re dies. Meanwhile, removing the CV can only help. And most tranny shops(good ones) will also remove it when replacing the trans.
