Confused between sensors
Old Nov 9, 2012 | 03:30 PM
_Project_'s Avatar
_Project_
Default Confused between sensors
Long story short pulled build sheet to make sure the tranny in my 96 was the 46RE.
I bought the truck used and of course i believe the engine was swapped. Here lies the problem. Just picked up a 97 46RE both 2x4 which i was told was same transmission.
Problem is when i get the 2 side by side my old one has a round sensor on the tail end closet to the driveshaft that the 97 doesnt.
Looked up the trans numbers one is 064-1 the other is a 064-5. Other then the sensor they are identical minus the studs on the bellhousing. Is it possible someone swapped and older 42re with a used engine in?
So lost right now. Any help is much appreciated.
Old Nov 9, 2012 | 06:49 PM
It's Me Patt's Avatar
It's Me Patt
Did you check the identification #'s on left side just above the the oil pan gasket surface?
http://dodgeram.org/tech/transmission/4xre.htm
Old Nov 9, 2012 | 10:09 PM
_Project_'s Avatar
_Project_
Ill check it tomorrow the truck isnt at my house. Pretty sure they are both 46res just different years
Old Nov 10, 2012 | 02:33 PM
It's Me Patt
I have the 46RE as well but no sensor in the extension housing..but the output speed sensor is located in the overdrive gear case...
