Old Aug 7, 2015, 02:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension
Print Wikipost
Leaking Power Steering Fluid
Old Nov 19, 2012 | 09:10 AM
dagarza's Avatar
dagarza
Lightbulb Leaking Power Steering Fluid
Hello, I'm new to the forum and I don't know much about Mechanics, but want to learn some basic repairs. I am having an issue with my 96 dodge 1500 leaking power steering fluid. Where should I start?
Old Nov 24, 2012 | 09:31 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
First you need a 2nd person and clean the area that maybe leaking, then fill the p/s unit and have the 2nd person start the engine and turn the steering to a lock position. Its either going to be a pressure hose, pump or sector shaft seal on the steering box. I'll move you post to the 2nd Gen Ram section. You may get more answers to your question from that section.
Old Nov 24, 2012 | 09:55 PM
Matt Nickerson's Avatar
Matt Nickerson
Likely your steering box is leaking from the pitman shaft seal, the area where the steering box is connected to the pitman arm...thats the most common leak spot anyways. My box has leaked from that area for a while, I just fill it up every once in a while because I dont care to fix it. Can you see where its leaking?
If its one of the seals on the steering box itself then its highly recommended to just replace the unit with one from either RedHead Steering Gear or Borgeson. Rebuilt units are usually a waste of money because they end up failing again.
Old Nov 24, 2012 | 10:33 PM
Welcome to DF! Start by identifying where it is leaking from. Hose? Pump? Reservoir? Steering box? Open the hood, crawl under, etc. Like is said, clean the area first then start looking. We also ask all new members to please read this:
https://dodgeforum.com/forum/2nd-gen...new-topic.html
Old Nov 24, 2012 | 11:03 PM
QuadCabLuv's Avatar
QuadCabLuv
like everyone else has said, clean area first then inspect for leak.
mine is actually leaking from the pump housing, must have got bumped hard during the motor swap
