power loss
Old Nov 22, 2012 | 04:19 PM
aofarrell2's Avatar
aofarrell2
Nope. You gotta take it apart to fix the gasket that caused it to get dirty in the first place.
Old Nov 22, 2012 | 11:08 PM
lone_wolf6968's Avatar
lone_wolf6968
well i looked in to it today and there wasn't any oil in it.
Old Nov 22, 2012 | 11:52 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
^PAH!
That's what I thought too with mine.
That sucker was mostly clean, but it ran through 1 qt per 100 mi....
And it bogged, pinged and sucked gas like a 454.
Old Nov 23, 2012 | 08:15 AM
^PAH!
Mines clean too ...Does not ping, bog or suck gas....well it does suck gas....they all suck gas....I'm happy with 13-14 mpg...but there is no immediate need for me to replace my plenum plate/gasket just yet. I'm waiting on Stewie to invite me to his new place to do mine...
Old Nov 23, 2012 | 11:42 AM
aofarrell2's Avatar
aofarrell2
^PAH!
Typical symptoms. Towing and you'll go through 1 qt of oil every 75 mi... But in my case had cracked heads and so it would go through a cup of coolant too...
Old Nov 26, 2012 | 11:34 PM
lone_wolf6968
well it not sucking that much oil maybe about a quart every 2500 mi. but it does go through coolent a lot.
Old Nov 26, 2012 | 11:51 PM
dodge dude94
Blown plenum and cracked heads.
CALLED IT!
Old Nov 27, 2012 | 01:32 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
for kicks, change back the intake air cleaner.
check all your vac lines. possibly you unhooked something.
Old Nov 27, 2012 | 08:42 AM
jondakotaguy's Avatar
jondakotaguy
I can say I could feel a slight difference when i swapped stock to Flowmaster 40.. it sounds great but yes its a little more restrictive.
And on your air intake, like they were saying your plenum is probably blown.. and your really feeling the effects of it with the little increase air.. changes the Manifold pressure greatly.. and probably causes and seems like it boggs on you...
Old Nov 27, 2012 | 10:24 AM
aofarrell2's Avatar
aofarrell2
Yep cracked heads and blown plenum. Just what I did. If you replace the heads, get the Odessa HD heads as they are slightly larger than factory heads... No remans, they will crack again. Count on about $2500 for that job if you are thorough in it...
