Horn sounds when High beams are switched on
but the switch does not control left and right lights separately. it has 1 headlight output and somewhere under the hood if splits to the 2 headlights. if you have a multi meter you could test the wiring. your left and right headlights have separate ground wires.
I'll put my meter on it tomorrow and see what it gives me. There are three wires a red (highbeams), violet/white (lowbeams), and black (ground). I'll have to double check the violet and black.
Thanks Wolfie I appreciate you time and input. If you can think of something else I'm all ears.
Timster
Timster
Headlight issue now put to Bed and repair order signed off and in the mail tomorrow.
I want to give all who chimed in on this thread a big Thanks especially you Crazzy Wolfie who stuck with me. Thanks
Timster
Timster
It was the friggen violet/white wire in part of the harness that was pretty much hidden under the frame. I should have looked a little closer instead of thinking the wiring was ok in that location. Should have known better.
