2nd Gen EFI in a 1st Gen
#62
#63
Found a double roller timing set made by Elgin, on Ebay for $36.00, shipping included. It has the same part number as the Cloyes double roller except it has a "T" before it. Cloyes # is C3028X. According to Cloyes, theres works on Dodge small blocks from 1958 to 2003. I assume the Elgin would work as well, even though there campatibility chart on ebay states it only works up to 1989. It also lists an interchange number with the Cloyes product. Thoughts on it? Oh... Here is a link:
http://www.ebay.com/itm/Timing-Set-Chrysler-318-360-273-sb-Dodge-Plymouth-Small-Block-Chain-Gears-/320924888847?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ab89d2f0f&vxp=mtr
#64
#66
#67
I have checked rockauto. Their price isnt bad, and may be where I purchase it. I just now saw your post about the cylinder walls. We must have posted at the same time, because when I started typing, nobody had answered yet. Lol
My cylinder walls did still have crosshatching, but had an obvious glaze over them. Too shiny/smooth, if that makes sense. I did a fast de-glaze/hone just to freshen it up for the new rings. about three to five seconds per cylinder is all.
I mic'd my cylinders diameter before and after (with good cleaning before each) and I came up with this: Before averaged 3.997 inches. After averaged just under 3.999 inches. Im still good to run STD sized rings, correct? Stock claims to be a 4" cylinder, and I am still right there. Also, this was done twice, with two different micrometers(mostly to satisfy any personal doubts of accuracy.)
#68
#69
I like to do that, unfortunatly, the funds arent always available to make a big order of everything I need. If I buy a couple of parts at a time, the wrath of the wife doesnt rain down quite as hard. Lol. Speaking of not spending too much... I found a re-ring kit on ebay that almost seems too good to be true. Rod and main bearings, rings and full gasket set for $189. Keep in mind, Im not doing a crazy powerhouse of a rebuild, just wanting to freshen it up and give it a new life. What do you think? http://www.ebay.com/itm/300854308499...84.m1438.l2649
#70
Anyone have insight on link from previous post? Too good to be true, or buy it and smile at the deal?
Quick update: I currently have all of my parts that I am going to be reusing soaking in a 50/50 mix of mineral spirits and kerosene. (Mostly because I ran out of mineral spirits and the gas station down the road sells kerosene at the pump). I need to order parts soon, as it looks like a buddy who is another DF'r is buying the engine that is currently in my truck. EFI is once again on the front burner!
