Vibration
hey guys i am having a weird problem when i am at a full stop with my wheel turned alot or a little bit when i go to take off i get this vibe as if like my front wheels are draging sideways and if only happens if i give it a fair about of gas if i just slowly turn or just idle turn it doesnt happen. Any idea's what it could be
First, it would really help if you would use some punctuations and capitalizations in your posts. I find your post very difficult to read and if I have to spend time trying to decifer what is written I usually just go on to another thread that I can understand. That being said, it could be understeer if your wheel is turned and you are punching it from a stop. The front tire is actually dragging until it can find grip. Other than that, check u-joints and inner fender for any tire rub that may be going on.
Wheel bearings can present like that, as well. Jack up the front of the vehicle, one tire at a time just a half inch or so off the ground. Put your foot tightly against the bottom of the tire. Grab the top of the tire and push it in and out. If there's no play, your bearings are fine. If there is play, the bearings need inspected and repacked, replaced if worn.
i have a 97 ram ss/t i am having the same problem i replaced all ball joints and u joints and i still have the vibration its mainly on a hard right turn
Trending Topics
my wheel bearing do have minimal play but they have been that way for some time and my vibrations had just started but i am going to replace them, this weekend
