Stalling issues
Old Dec 1, 2012 | 09:24 AM
SOA's Avatar
SOA
Default Stalling issues
I have a 99 dodge 1500 ram 5.9 liter with 150,000 miles that starts but will not stay running unless I give it gas. It doesn't happen all the time. There is no CEL but the Air bag light comes on now and then. I have changed the IAC, TPS, MAP, O2 sensor as well as plugs and wires. My battery is new and the connections are fine. I am looking for some guidance as to what I should be looking at now. Any help would be greatly appreciated. Thanks in advance.
Old Dec 2, 2012 | 09:01 AM
SOA's Avatar
SOA
Just wondering if there is any body out there that can help with my stalling issue. I see people have looked at my post but no one has responded. Just trying to find some direction. I am hearing that it could be my crank shaft sensor. Thanks in advanced
Old Dec 2, 2012 | 08:09 PM
master tech's Avatar
master tech
Site Moderator & Tech
I will move your post to the 2nd Gen Ram section. You will get more response there, than the new member section.
Old Dec 2, 2012 | 09:18 PM
QuadCabLuv's Avatar
QuadCabLuv
i had the same issue with my 95. It would not hold an idle and would just stall. Ended up being a weak spark. i replaced the ignition coil and distributor cap and it fixed it. However it could also be cause by a loose ground wire or a vacuum leak.
