engine swap questions 318 to the 360
Long story short on the plenums: They suck. There is a repair that works and even if you dont show signs of needing it, do it anyway. There is a crazy lengthy thread on just that subject, and you should give it a read. Pretty interesting really, and it will tell you everything you could ever want to know about it and then a whole bunch more.
on
I disagree ^ in part.
If the owner confidently determines their gasket is intact and has no interest/need to do other upgrades, then I say leave the gasket in place till it does break. At minimum to do the following: cap, rotor, wires, plugs, PCV, water pump, timing chain, and oil pump.
on
simply b/c not all of them break....
Plus, there are cases reported here where ppl have replaced the gasket and they still have them fail.
To think once it's fixed = never to break again is false
I believe zman has said he needs to redo his. Not picking on him in any way to be critical.
But if it was me doing a motor swap, knowing what I know, I'd replace it anyway. Hell I was gonna buy a Hughes AirGap, had the mouse on the order button with money on the card, just couldn't bring myself to do it
![Frown](https://dodgeforum.com/forum/images/smilies/frown.gif)
Zman has mentioned weird oil loss a time or two. Maybe he'll find the cause one day.
Exactly. If he wasnt swapping engines, I would agree with you in leaving it alone till it fails, but since the engine is out of the truck anyway, I think it would be in his best interest to do it before the install. Cheap insurance IMO. Not a gaurentee that it wont ever fail, but it would help me sleep easier at night if it was my truck.
